Tail lights leak and back seats collect water???
Old Dec 13, 2004 | 08:52 AM
Ben_si's Avatar
Default Tail lights leak and back seats collect water???
Im going to seal my tail lights because they leak and I end up with a giant puddle of water in my spare tire holder, I have hurd of this problem with honda's and acura's. My back seats must have hole's under them I guess well somehow the water gets into the bottom of the back seats. Has anyone else have this problem or am i just smoking way to much crack these days???
Old Dec 13, 2004 | 08:54 AM
civictildeath's Avatar
Default Re: Tail lights leak and back seats collect water??? (Ben_si)
does the window leak??
Old Dec 13, 2004 | 08:55 AM
khmboostedeh2's Avatar
hatchback i assume??
i bet the water in the wheelwell is just travelling to the back seats whenever you brake hard. my suggestion? id just drill a small hole into the wheel well (avoiding the gas tak of course), then clear coat it.
Old Dec 13, 2004 | 08:57 AM
-Gambit-'s Avatar
its your taillight gaskets that leak waters, and the waters gets under your rear seat from you braking. When you brake all the water that is in your spare tire well goes foward, so a little water ends up under your rear seat.
Old Dec 13, 2004 | 09:00 AM
Ben_si's Avatar
Default Re: Tail lights leak and back seats collect water??? (-Gambit-)
I have a 00 si coupe and there is like ******* a gallon of water in my back seat, I dont really understand what you guys are saying what do i have to do???
Old Dec 13, 2004 | 09:05 AM
lay a dry towel down where the wat seems to be on the seat.take a big *** cup of water and dump it on the window closest to the problem area ie. left side of seat dump on left side window and left side of rear windshield. dump the water all the way across the top of the window(s) and see it it leaks
Old Dec 13, 2004 | 10:05 AM
Deemeetree's Avatar
Electrician
Good thing I have a Sedan. Whatever water builds up stays in the "tub" where the spare tire sits. I actually have a visible hole on the floor of my trunk where the water is probably coming from. But it's not that bad at all.
I guess look for any visible holes on the floor and cover them up with tabs of some sort.
Old Dec 13, 2004 | 10:28 AM
99hatch's Avatar
Default Re: (Dimi)
i have a hb and my spare tire area fills up too. recently the floor on the drivers side has started to get wet and stay that way also
Old Dec 14, 2004 | 08:42 AM
Ben_si's Avatar
Default Re: (99hatch)
I took out my back seat again last nite (more ******* water) so i checked it out...went to Home Depot got a giant *** tube of silicone and started patching anything that looks like a hole that water might threw. I did it last nite and it hasnt rained yet so im keeping my back seat out untill it rain's to see what the deal is. Thanks for all the help thou if what I did works ill post up pic's of what hole's I pluged
Old Apr 18, 2005 | 07:15 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: Tail lights leak and back seats collect water??? (Jeterkm02)
look for a plug in the spare tire holder!
Delicieuxz
23
Nov 13, 2017 09:45 PM
itsmedavid
Jul 18, 2007 04:32 AM
hondaracin24
Nov 28, 2006 06:44 PM
illusion
Dec 11, 2004 08:21 PM
8alaRm
Jan 9, 2003 08:24 AM
