do i need a different ecu in my 91 si with a d15b?
You should be fine with that ecu, there's not enough of a difference in engine size to make a big difference.
I've done a few swaps like this for people just needing a fresher motor. Just reuse your current intake manifold and distributor and you should be fine. You will have to wire up the fan switch but other than that it is a direct bolt in.
nmhuntr
Sep 30, 2009 05:56 AM
