Air Intake Bypass Solenoid HELP
Old Dec 12, 2004 | 01:04 PM
Stoich EG2's Avatar
Default Air Intake Bypass Solenoid HELP
I have a JDM H22A and I do not see an Air Intake Bypass Solenoid under the intake manifold. Do I have to have it to have the secondary runners work? is there a way to get around it? if not, is anyone selling one? I need it asap.
Old Dec 12, 2004 | 01:08 PM
Hawkze_2.3's Avatar
Default Re: Air Intake Bypass Solenoid HELP (Advan06)
EDIT, I l thought that pic was from a different spot
Modified by Hawkze_2.3 at 2:42 PM 12/12/2004
Old Dec 12, 2004 | 01:12 PM
Stoich EG2's Avatar
Default Re: Air Intake Bypass Solenoid HELP (Hawkze_2.3)
does that mean i need it? hahaha, i have no clue what that meant thanks for input sir
Old Dec 12, 2004 | 01:36 PM
Turbogixxer's Avatar
Edit: for better reading.
Advan06, You IABs has a broken fitting. You need to talk to the person you got your swap from to get you a new one.
Old Dec 12, 2004 | 01:48 PM
PreludeSiTdriver's Avatar
Hey man I just got a h22a with one. I swapped my h22a1 onto it. However, from what I was told from the guy biulding the motor, he stated that, that isnt really needed. It only like 1-2hp if you do have it. It just open up the internal runners like you stated. I do have one if you want it let me know. It is a jdm one. But i dont think it has that IAB i swapped mine
Old Dec 12, 2004 | 03:05 PM
2lude4u's Avatar
Default Re: Air Intake Bypass Solenoid HELP (PreludeSiTdriver)
You're going to need that to run you IAB's. I'm currently running with mine, but will remove it soon for a hawged out/single staged manifold and won't need my IAB Controller anymore. I'm in the Bay Area, if you want it.
Old Dec 12, 2004 | 04:27 PM
mgags7's Avatar
you could get away without the whole box....but there is a sensor on it you will need.....that sensor tells it when to open em up....the box just provides a better vacuum charge.....i would give you the extra one i got with my swap but it was cracked on my h22 when i got it.......
you definately should have it, 1-2 hp is an understatement, without your car will bog terribly below 4500 rpm.....find one....im sure theres some out there....
Old Dec 15, 2004 | 12:03 PM
Stoich EG2's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">Edit: for better reading.
Do i need that IAB check valve also?
Old Dec 15, 2004 | 12:21 PM
prelittlelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreludeSiTdriver &raquo;</TD></TR><TR><TD CLASS="quote"> However, from what I was told from the guy biulding the motor, he stated that, that isnt really needed. It only like 1-2hp if you do have it. </TD></TR></TABLE>
who ever told you that was a retard, do you think honda would have wasted all the time and money in engineering the dual runner setup for a just 1 -2 hp, NO! and the benifit isn't in HP as the dual runners help with low end torque.
edit: and yes you need the check valve, that black container is a vacume canaster, the check valve with make sure hte vacume doesn't "escape" whe you go full throttle
Old Dec 17, 2004 | 12:02 AM
Stoich EG2's Avatar
Default Re: Air Intake Bypass Solenoid HELP (prelittlelude)
can i temporarily run my car without it? the IAB solenoid that is... and the plug...
Old Dec 17, 2004 | 02:39 AM
thehondaguru's Avatar
I have one I can sell you for cheep. Just IM me.
Old Dec 17, 2004 | 05:38 AM
Sam1am26's Avatar
Default Re: Air Intake Bypass Solenoid HELP (95 lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 lude &raquo;</TD></TR><TR><TD CLASS="quote">I have one I can sell you for cheep. Just IM me.</TD></TR></TABLE>
I have a few... lol...
Old Dec 19, 2004 | 12:19 AM
Stoich EG2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Advan06 &raquo;</TD></TR><TR><TD CLASS="quote">can i temporarily run my car without it? the IAB solenoid that is... and the plug...</TD></TR></TABLE>
Old Dec 19, 2004 | 07:58 AM
mgags7's Avatar
yes it will run, but suck
Old Dec 19, 2004 | 10:58 AM
jdmcivicferio's Avatar
OR you can do what is even better and run the vacuum line from the diaphram directly to the intake manifold and bypass the whole box complety
Old Dec 19, 2004 | 11:56 AM
Stoich EG2's Avatar
Default Re: (jdmcivicferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicferio &raquo;</TD></TR><TR><TD CLASS="quote">OR you can do what is even better and run the vacuum line from the diaphram directly to the intake manifold and bypass the whole box complety </TD></TR></TABLE>
yeah, i got the engine that way. it was bypassed but i was still wondering if it'd work. thanks guys
Old Dec 19, 2004 | 02:16 PM
what , no! thats a bad idea, the vacume cannister is there because as soon as the manifold presure changes to a lower presure vacume the higher vacume in the cansiter held in by the check valve, holds the IABS closed
if you hook it directly up, as soon as the vacume is too little the spring will over come the weak vacume, its also completely variable which produces no constant behavior
also the time that it would be worst is at WOT as soon as you mash the gas to wot at say 2k the IABs will instantly lose vacume and they will open and the car will fall on its face!
you need the vacume canister, any vacume canaster will work, and mostly any honda vacume solinoid will work to, do it the right way
Old Dec 30, 2004 | 10:07 AM
duofilm's Avatar
Default Re: Air Intake Bypass Solenoid HELP (turbogixxer)
What OBD diagram is this for turbogixxxer?. It seems theres another floating around similar to this but a few things missing like the starting air boost? Let me see if I could find the link
Here it is https://honda-tech.com/zerothread?id=385918
It's somewhere in the middle.
Old Dec 30, 2004 | 01:22 PM
Default Re: Air Intake Bypass Solenoid HELP (duofilm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duofilm &raquo;</TD></TR><TR><TD CLASS="quote">What OBD diagram is this for turbogixxxer?. It seems theres another floating around similar to this but a few things missing like the starting air boost? Let me see if I could find the link
It's somewhere in the middle.</TD></TR></TABLE>
both are for obd1 and probably even for the early obd2 h22s
but both are correct, some intake manifolds have the starting sir boost valve and some don't . the picture in the link you provided is from a helms manual which are the factory honda manuals, so it is correct,
Old Dec 31, 2004 | 01:31 AM
duofilm's Avatar
thx for the info!
Old Jan 4, 2005 | 05:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duofilm &raquo;</TD></TR><TR><TD CLASS="quote">What OBD diagram is this for turbogixxxer?. </TD></TR></TABLE>
Sorry for the late reply, It is from a 5th gen prelude, there is a 4th gen. As prelittlelude pointed out about the starting valve.
Old Mar 16, 2005 | 02:01 PM
Silpheed's Avatar
I have the H22 dropped in my 99 accord. I do not have the plug to plug into the solenoid. I did some research here and I found that I use the wire from b16 i guess. I am not sure if i understood this correct. Any help would be nice.
Oh. I am using the accord OBD2 wire harness
greddyboy
May 11, 2006 12:53 AM
accordmandan
Jul 28, 2005 02:51 PM
f22b4me
Oct 3, 2004 09:28 PM
vincent97gsr
Dec 8, 2001 04:50 PM
