Oil surge and VTEC cut off
Old Dec 12, 2004 | 06:01 AM
Fink2iCe's Avatar
Default Oil surge and VTEC cut off
I was going through th engine oil archives and read that oil starvation can cause the car to drop out of vtec when cornering, see Robs (Bbasso) comment:
https://honda-tech.com/zero...age=1
I was out in my Teg Type-R on Friday on "performance driving day" for guys with Lotus's with the Honda K20A engine conversions (I sneaked in with a friend).
Anyway I've been wondering what the power loss was all about when I exited a corner after taking it very hard. The motor seemed like it had lost power. I might have been in 2nd gear (vtec mode) when I exited I think thats when I lost power because as I shifted up into 3rd there was no increase in power so I thought it might be a tranny faliure. After a second or so (seemed like forever) of worry and frantically trying to engage the tranny I got power and everything was alright again.
Is an oil surge the most likely cause of this incident?
Old Dec 12, 2004 | 06:33 AM
uNF$@#!'s Avatar
Default Re: Oil surge and VTEC cut off (Fink2iCe)
welcome to h-t, where people flame you for starting multiple threads on the same subject.
Old Dec 12, 2004 | 06:40 AM
Willard's Avatar
the oil level was most likely low.
check the level and make sure it is at (or slightly above) the upper dot.
Old Dec 12, 2004 | 06:44 AM
.RJ's Avatar
.RJ
Default Re: Oil surge and VTEC cut off (Willard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">check the level and make sure it is at (or slightly above) the upper dot.</TD></TR></TABLE>
Mugen oil pan
Old Dec 12, 2004 | 06:54 AM
Fink2iCe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">the oil level was most likely low.
No the oil level was perfect, I only had an oil change 2 weeks ago and I checked the oil when I got back home from the event when the engine had cooled down.
Modified by Fink2iCe at 4:58 PM 12/12/2004
Old Dec 12, 2004 | 07:34 AM
Chris F's Avatar
I vote for fuel starvation. I get it if I ever get down to a half tank of gas.
How much power did you lose? How rough was it running?
Old Dec 12, 2004 | 07:57 AM
Fink2iCe's Avatar
Default Re: Oil surge and VTEC cut off (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
How much power did you lose? How rough was it running?</TD></TR></TABLE>
Fuel starvation with half a tank? That's odd. You know what? I was on half a tank when that happened..
It wasn't running rough at all. The engine was running, but the revs were dropping as if I was not giving it any gas.
Old Dec 12, 2004 | 08:05 AM
pyromaster's Avatar
Ssounds like fuel starvation to me too. The exact same thing happens to me at Little Talladega making a right hand turn with some elevation changes. I had between 1/4 -1/2 a tank when it happened I was accelerating and then I oculd hear the engine run but the revs dropped about a grand and then I was pretty much out of the turn and started accelerating again. Scared me a bit for a few laps until I realized what was going on and pitted and added more gas.
Stupid sloshing fuel
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fink2iCe &raquo;</TD></TR><TR><TD CLASS="quote">
It wasn't running rough at all. The engine was running, but the revs were dropping as if I was not giving it any gas.</TD></TR></TABLE>
Old Dec 12, 2004 | 08:06 AM
.RJ's Avatar
.RJ
I have never seen fuel starvation on track, even with the gas light glowing bright orange in the turns.
Old Dec 12, 2004 | 10:10 AM
Willard's Avatar
Default Re: Oil surge and VTEC cut off (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">I have never seen fuel starvation on track, </TD></TR></TABLE>
= you are slow.
thru T2 at VIR... (showing ~1/4 tank) = cuts out till I straighten up for the entry to T3.
Old Dec 12, 2004 | 10:13 AM
.RJ's Avatar
.RJ
showing 1/4 tank while stopped or in turn? when the lite is on in turns, it will register over 1/4 tank in the padd0ck
Old Dec 12, 2004 | 10:49 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">I get it if I ever get down to a half tank of gas</TD></TR></TABLE>
I am teh suXor. Meant to say, less than half a tank. 1/2 (at rest/straightaway) is OK, but anything less I starve on long corners. It shows up first on carousels.
Old Dec 12, 2004 | 10:50 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">showing 1/4 tank while stopped or in turn? when the lite is on in turns, it will register over 1/4 tank in the padd0ck</TD></TR></TABLE>
You must be going slow to look at the gauges in a turn.
Old Dec 12, 2004 | 10:54 AM
.RJ's Avatar
.RJ
j00 must be a n00b if j00 cant
Old Dec 12, 2004 | 11:04 AM
pyromaster's Avatar
I had the kaa actually cut off on me in the middle of T2 at Roebling Road once due to fuel starvation I let it sit for a sec and it cranked right back up. There was ~1/4 tank indicated. That's when I learned to buy a 5qt gas can and fill that up for topping off on the last session of the day.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">I have never seen fuel starvation on track, even with the gas light glowing bright orange in the turns.</TD></TR></TABLE>
Old Dec 13, 2004 | 04:14 AM
Willard's Avatar
sitting still it showed a little under 1/4 tank. thru T1 and T2 (both right handers) the light comes on (sometimes) but the car cuts out there (nowhere else on that track)... i have the video.
Old Dec 13, 2004 | 04:16 AM
.RJ's Avatar
.RJ
I havent taken it out that low on gas yet
Old Dec 13, 2004 | 06:36 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">j00 must be a n00b if j00 cant </TD></TR></TABLE>
I know you're right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pyromaster &raquo;</TD></TR><TR><TD CLASS="quote">That's when I learned to buy a 5qt gas can and fill that up for topping off on the last session of the day. </TD></TR></TABLE>
Ha, I fill up 3 times in a day. I can't make 2 full sessions without fuel starvation at the end of the 2nd one. I use 3.5-4.5 gallons on a full session. (My car is thirstier than most, tuned to 11.5:1)
-Chris
type-r 01 886
Nov 8, 2004 07:05 PM
phatrick2332
15
Jan 10, 2004 05:51 PM
RiCE On IcE 2
Jun 25, 2003 01:00 PM
b18c1delly
Aug 23, 2002 06:57 PM
