B18C5>into>85 crx si
get it if its cheap, but i gotta warn you that any swap into the 87 and lower models of crx will be harder to do than the 88+ because most after market parts are made for the 88+ and you whould have to make custom mounts for it to fit in your 85 crx. But its possible if you really wanna.
well i maye be wrong about the custom mounts part, search for "1st gen swaps" and you should get some helpful info . This might help you on the mounts part https://honda-tech.com/zerothread?id=83475
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control »</TD></TR><TR><TD CLASS="quote">and you whould have to make custom mounts for it to fit in your 85 crx. But its possible if you really wanna. </TD></TR></TABLE>
Not true. Hasport makes mounts for this swap.
Hasport has pretty much everything you need to do this swap. Your going to need to use a cable transmission. Id say do it, a B18C5 would be such a blast to drive in a 1st gen......if your car is carbed then this swap is going to be alot of work
if you can put a B16, you can put a B18C5. The only think you need to worry about is the hood clerance. the C5 sits about 5/8" taller than the B16 at the valve cover. The rest is the same. You need to use a cable B series tranny though, I don't know if the hydro would fit since it is about 3/4" longer (left to right) than the cable ones.
Your avatar rocks!
got the full size pic?
Your avatar rocks!
sorry no fullsizes, theres someone on the rex forums that copyed it from meh...
but i cant sell my car dude, its like a pride thing, love it too much!
is there anyone that has put a B18C5 into a 85 crx?
somebody had a 1st gen crx with a C5 in the for sale section a few weeks back, looked great.
https://honda-tech.com/zerothread?id=1052432
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt »</TD></TR><TR><TD CLASS="quote">Not true. Hasport makes mounts for this swap.</TD></TR></TABLE> i know its not , looks at the other post before posting <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control »</TD></TR><TR><TD CLASS="quote">well i maye be wrong about the custom mounts part, search for "1st gen swaps" and you should get some helpful info . This might help you on the mounts part https://honda-tech.com/zerothread?id=83475</TD></TR></TABLE>
