Heater problem
Old Dec 11, 2004 | 09:49 PM
dcrbin22's Avatar
Default Heater problem
My heat is on no matter if i put in on cold or hot. what could cause this to happen ?
Old Dec 11, 2004 | 10:00 PM
BrokeLude's Avatar
Default Re: Heater problem (dcrbin22)
The cable fell off the valve under the passenger side dash.
Old Dec 11, 2004 | 10:16 PM
dcrbin22's Avatar
Default Re: Heater problem (BrokeLude)
You have had this problem before ? The slider does seem to move pretty easily back and forth> I will check it out in the morning thanks for the info. where exactly under the dash is it ? more towards the center console or the passenger door ?
Old Dec 12, 2004 | 08:11 AM
hOndafienD 04's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeLude &raquo;</TD></TR><TR><TD CLASS="quote">The cable fell off the valve under the passenger side dash.</TD></TR></TABLE>
check the cable
Old Dec 12, 2004 | 11:40 AM
mgags7's Avatar
the part where the cable connects to....the heater contol valve (you like the invented name) haha.....anyways....is out under the hood....
the cable goes thru the firewall probably 4 inches to the passneger side off center.....
find that under the hood....right down the middle of the firewall...two about 1 inch diameter heater hoses that go through, and then one that goes into the firewall toward the heater core....
locate the cable, then have someone go inside the car and move the slider, that will make sure its connected inside, b/c if it is you will see it move.....if not let us know...
theres a little peg on top of the valve, and the cable is a loop, just put the loop back over the peg.....done
good luck with it
Old Dec 12, 2004 | 08:23 PM
dcrbin22's Avatar
Default Re: (mgags7)
Yeah that was the problem the cable came of the peg. Its all set now thanks for the help.
navin
Dec 16, 2007 10:04 PM
94_CRVtec
Oct 29, 2004 02:06 PM
speedbeast
May 9, 2004 01:53 PM
is3oo
May 4, 2004 06:21 PM
