Finally, Poormans R on the stand (beginning the build)
Old Dec 11, 2004 | 09:38 PM
Cory man's Avatar
Default Finally, Poormans R (beginning the build)
After too long of a wait and lots of research later the ol B18c has arrived. Here are a few pics:
The free gsr head from a warranty claim at work(gotta love workin at the dealer)
My plans are basically an OEM rebuild, bore, hone the usual with O.S. p30s. I havent thought about cams yet but I'm really leaning toward staying OEM with everything internal just to prove the potential it has. Suggestions/comments welcome. TIA
BTW I need a few parts that didnt come with the block
-water pipe(from water pump to t stat housing)
-crank pulley
-t stat housing
Im sure there will be more but till then enjoy the pics. TIA
Old Dec 11, 2004 | 10:00 PM
B18OnTop's Avatar
Default Re: Finally, Poormans R (Cory man)
Very nice. Id go with a set of itr cams. good luck
Old Dec 11, 2004 | 10:39 PM
IN VTEC's Avatar
I've got a water pipe and thermostat housing/thermostat you can have at the expense of shipping if you can use (and don't mind using) OBD-1 parts.
The OBD-1 water pipe is a plus if you want to run an OEM oil cooler and the stock P72 intake manifold.
The OBD-1 thermostat housing, I'm not a big fan of, since it has an extra coolant port that I find redundant (as did Honda when they changed it on OBD-2 motors).
Old Dec 12, 2004 | 03:20 AM
Surubasi00's Avatar
haha why you callin it a poor man's type R when its just gonna be a built up GSR hehe
Good luck!
Dave
Old Dec 12, 2004 | 06:14 AM
Greenery18's Avatar
Default Re: Finally, Poormans R (Surubasi00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Surubasi00 &raquo;</TD></TR><TR><TD CLASS="quote">haha why you callin it a poor man's type R when its just gonna be a built up GSR hehe</TD></TR></TABLE>
lol, yeah where are the hype "R" parts?? isn't a poor man's type r just a gsr block + type r head?
Old Dec 14, 2004 | 07:48 PM
Cory man's Avatar
Default Re: Finally, Poormans R (Greenery18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greenery18 &raquo;</TD></TR><TR><TD CLASS="quote">
lol, yeah where are the hype "R" parts?? isn't a poor man's type r just a gsr block + type r head?</TD></TR></TABLE>
Actually Im just using the GSR head for the LMA's and the intake valve springs. The B16 head thats in my car now will be bolted to this GSR block.
Old Dec 14, 2004 | 07:58 PM
slammed_93_hatch's Avatar
hey let me know about the random parts you need, i nadded my JDM ITR motor, and i have the block with everything left on it. and a thermostate with only 2,000 miles on it
Old Dec 14, 2004 | 08:54 PM
gSIr's Avatar
I'm doin the same setup you are. I am using a 95 gsr block and a 99 b16a2 head. I honed it and put a set of p30 pistons in, tomorrow my arp head studs should arrive. I'm goin to pull the head of mine this weekend finish buildin it and swap it in before sunday. For now i'm goin to use the gsr cams but i want to upgrade to the itr valvetrain and cams or a set of skunk 2s
Heres a pic of mine, sorry bout the size
Modified by gSIr at 10:30 PM 12/14/2004
Old Dec 14, 2004 | 09:40 PM
Cory man's Avatar
Default Re: Finally, Poormans R (gSIr)
Glad to hear that your buildup is going well. Im a bit torn whether or not to use ARP head studs. I havent really researched much on that yet, but there will be plenty of time for that. Im hoping for about 175-185 or so whp give or take. Hit me up and let me know how it goes.
Old Dec 14, 2004 | 09:47 PM
gSIr's Avatar
i would use the arp studs, i don't want to risk leaks, might as well do it right the first time. My problem is i don't know if stock 240cc injectors and a vafc will be enough for high fuel need with the extra compression
Old Dec 14, 2004 | 09:53 PM
EMO-anthony's Avatar
look into AEBS headstuds.
Old Dec 15, 2004 | 02:38 PM
NSTY Z33's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gSIr &raquo;</TD></TR><TR><TD CLASS="quote">I'm doin the same setup you are. I am using a 95 gsr block and a 99 b16a2 head. I honed it and put a set of p30 pistons in, tomorrow my arp head studs should arrive. I'm goin to pull the head of mine this weekend finish buildin it and swap it in before sunday. For now i'm goin to use the gsr cams but i want to upgrade to the itr valvetrain and cams or a set of skunk 2s
Modified by gSIr at 10:30 PM 12/14/2004</TD></TR></TABLE>
Don't mean to be a dick, that hone looks like ***. I thought it was supposed to be crosshacth pattern? Did you measure it at the end?
Old Dec 15, 2004 | 02:50 PM
99 TYPE R's Avatar
i have itr cams 4 sale
Old Dec 15, 2004 | 03:07 PM
gSIr's Avatar
Default Re: Finally, Poormans R (CRXDelSol!)
actually it is, its just really hard to see because of the flash of the camera. I recently built rebuilt a motor for a 3000gt vr4, i used the same technique and it worked just fine
Old Dec 15, 2004 | 03:24 PM
NSTY Z33's Avatar
Oh, ok. Have you measured?
Sorry i care so much, just want to know
Old Dec 18, 2004 | 04:39 PM
rjay8604's Avatar
Default Re: (CRXDelSol!)
Good luck from a local (florissant). I think CTR cams would be the way to go.
Old Dec 18, 2004 | 05:04 PM
eg6h8k's Avatar
Default Re: (rjay8604)
great build.. you will get good power..
mine was w.
udsm itr pistons and rods
2 layer HG
slight polish job by me
and it mad 173hp and 126tq...good **** cheap and healthy motor..gl man
Old Dec 19, 2004 | 01:14 PM
Cory man's Avatar
Default Re: (eg6h8k)
Everything is torn down, now I have to find a good machinist. Rjay I sent you a PM. Hopefully things will start going together sooner than later. I cant wait to make some REAL power with all OEM parts. Thanks for the comments everyone.
UserX826
Mar 13, 2009 11:58 AM
NABeastRR
Jun 23, 2008 09:02 AM
NABeastRR
Southeast (Sales)
Jun 23, 2008 09:01 AM
homey dont play dat
Sep 29, 2006 08:58 PM
