? about lsd
Old Dec 11, 2004 | 07:33 PM
2bars's Avatar
Default ? about lsd
before i get flamed, i did search and found nothing.I broke my axle on my way home tonight, with a quaife lsd it should continue to move right? But the engine rev up and the car not moving, why?
Old Dec 11, 2004 | 07:40 PM
atcrx's Avatar
Default Re: ? about lsd (2bars)
No it will not move if one axle is broke. I may not exp[lain it right but the lsd tries to distribute the power equally to both axles. But when one is broke all the power is transmitted to the good axle side and the clutches in the lsd cannot overcome that and it slips hence the name limited slip differential.
Old Dec 11, 2004 | 08:20 PM
N20civicB18's Avatar
Default Re: ? about lsd (atcrx)
yeah... if you had a spool you would still be able to drive... lol i dont know how "drivable" it would be though..
Old Dec 11, 2004 | 08:21 PM
2bars's Avatar
I got this from quaife website.
The Quaife Differential powers both drive wheels under nearly all conditions, instead of just one. With an ordinary open differential, standard on most cars, a lot of precious power is wasted during wheelspin under acceleration. This happens because the open differential shifts power to the wheel with less grip (along the path of least resistance). The Quaife, however, does just the opposite. It senses which wheel has the better grip, and biases the power to that wheel. It does this smoothly and constantly, and without ever completely removing power from the other wheel.
nextproject97
Transmission & Drivetrain
Apr 6, 2009 06:47 PM
killrB
Dec 4, 2007 10:21 AM
deathofadam
30
Jun 15, 2007 05:13 AM
jep
Jun 12, 2006 02:55 PM
euclid
Sep 16, 2004 07:13 PM
