Ok the next steps on a b16a build up
Old Jan 3, 2002 | 06:24 AM
91sifreak's Avatar
New User
Default Ok the next steps on a b16a build up
I am buying some stuff today for my b16a swap into a 91 civic Si. What cams should I go with for good daily driving but still give me that extra oomfff, should I just stick with a ctr intake and leave the si-r exhaust, buy both ctr cams, or another after market product, spoon or toda, something of that nature? I am sending the computer out to be reprogrammed, cold ait intake, exhaust, ITR intake manifold, port matched throttle body to 68mm. Thanks for any input all.
Old Jan 3, 2002 | 06:50 AM
rainforest's Avatar
Default Re: Ok the next steps on a b16a build up (91sifreak)
ok just stick with r cams they are the easiest cams to tune and even thuogh aftermarket cams usually are not unrealiable but the less aggresive by just a little is the r cams. go to all motorhonda.com to be surprised by the aggresiveness of the itr/ctr cams.
Old Jan 3, 2002 | 07:02 AM
91sifreak's Avatar
New User
Default Re: Ok the next steps on a b16a build up (rainforest)
motorhonda.com is a not found site but I think I will stick with the r cams. should I also get a Vafc or just reprogramm the ecu, or both?
Old Jan 3, 2002 | 09:59 AM
ahcjar103's Avatar
CTR pistons and a JG pro series head. there are a couple other things to do too, but i can't tell you that
Old Jan 3, 2002 | 10:12 AM
Spade's Avatar
If you want to adjust your VTEC engagement get a Hondata ecu. Sure they are a little pricey but, they are great!
Old Jan 3, 2002 | 10:58 AM
Katman's Avatar
you can't go wrong with ANY 'R' cams at all. ITR/CTR - OEM cams rule. They make more power than stock dohc vtec cams anyways, and it's best to have both 'R' cams to gain full power from these cams -- but for maximum power, adjustable cam sprockets+ an ECU upgrade+ a fuel/vtec controller+ some dyno tuning will yeild the best outcome of power from the cams on your engine.
[Modified by Katman, 11:58 AM 1/3/2002]
Old Jan 3, 2002 | 01:42 PM
SuperMan19's Avatar
New User
He put in www.allmotorhonda.com
He just didn't spell it all together or the words got seperated.
Old Jan 3, 2002 | 04:38 PM
91sifreak's Avatar
New User
Default Re: Ok the next steps on a b16a build up (MyKarsNameIsMichelle)
good deal all, Thanks for the info and katman I am sending my ecu to you. I guess I will get the both of the ctr cams and a clutch, thanks for all the input.
Do you think I should upgrade the vavletrain, like the springs and such as well? Just to be safe, right?
Old Jan 3, 2002 | 05:12 PM
pelotudo's Avatar
Hey 91SiFreak,
Where are you in O-Town? I'm in Mt. Dora down 441. Maybe we can meet somewhere. Are you getting your parts locally? If so, where and what kind of prices I might jump on your upgrading bandwagon and blow some $$$.
Jonathan
Old Jan 3, 2002 | 05:57 PM
Katman's Avatar
word ta that
Old Jan 3, 2002 | 06:19 PM
Kamin's Avatar
Default Re: Ok the next steps on a b16a build up (Katman)
for a semi good upgrade
ITR intake manifold
thats on my list right after headers.
Old Jan 4, 2002 | 05:14 AM
91sifreak's Avatar
New User
Default Re: Ok the next steps on a b16a build up (KAMiN)
I already have an ITR manifold as well, with a port matched throttle body to the same bore as the ITR, so I have that covered, found one for cheap and got it before all else. Hey Pelo i work of 441 and go to racing works for minor parts and order most but e-mail me.
crackerjacker006
Aug 23, 2005 11:05 PM
respectblades
Jun 26, 2003 06:35 AM
4ghatch
Dec 22, 2002 01:05 PM
vtecdc2
Sep 2, 2002 07:52 PM
B00ST2nR
Apr 17, 2002 01:26 PM
