95 Prelude VTEC threw Engine Code - help!
Old Dec 11, 2004 | 06:13 PM
Import RP's Avatar
Default 95 Prelude VTEC threw Engine Code - help!
Hey guys, I've got a 95 Prelude VTEC. Today my check engine light came on - so I checked the service connector and it threw code #12. This is the Exhaust Gas Recirculation (EGR) code. The car seems to be running fine though... just wondering if anyone else has had this code thrown and what the remedy would be. Any info would be greatly appreciated!
Thanks guys,
Jeff
Old Dec 11, 2004 | 07:28 PM
RedlinedVTEC's Avatar
Default Re: 95 Prelude VTEC threw Engine Code - help! (Import RP)
Disconnect the negative battery cable for 5 minutes and then put it back on and see if it still throws this code. If so then do the troubleshot via your helms to see if for whatever reason your EGR went bad.
Old Dec 14, 2004 | 10:06 PM
Fongman's Avatar
That code is sometime on because the EGR is not working or is leaking... you should test it with a vaccum pump and make sure it holds vaccum. If not replace with a new one... you will fail smog and have high nox reading....
azmal3125
Nov 21, 2017 10:05 AM
toxicsynergy
Jul 29, 2008 05:18 PM
eg6ryder
Mar 3, 2006 08:48 AM
Import RP
Dec 12, 2004 11:55 PM
brian2903
May 2, 2004 02:46 PM
