LS vtec which engine harness do i need?
Old Dec 11, 2004 | 09:23 AM
slayersluck's Avatar
Default LS vtec which engine harness do i need?
Hey guys...i'm going to do drop ls/vtec soon in my car ...obd-2 bottom block and a obd-1 b16 head... I was wondering if I need a different engine harness or if I can just use my LS engine harness... if i do need a different engine harness... which one do i need? any help would be SWEET!...THANK IN ADVANCE!!!
Old Dec 11, 2004 | 12:40 PM
DIFFUT'S INC.'s Avatar
Default Re: LS vtec which engine harness do i need? (slayersluck)
u can use a obd 2 DOHC VTEC wire engine harness and get a obd 2 to obd 1 harness to then make the motor run on a obd 1 ECU
Old Feb 19, 2005 | 10:27 PM
ek_b16's Avatar
Default Re: LS vtec which engine harness do i need? (DIFFUT'S INC.)
I believe you can just use your harness and add the vtec wires along with the knock sensor.. that should work..
toolbox21
Jun 12, 2012 09:50 AM
SIR_APPROVED
Dec 18, 2009 06:59 PM
PaChiLa Leader
Nov 8, 2008 10:52 PM
EGJDM
May 4, 2003 06:03 AM
