What would it take to make this LSD fit my tranny
if i remember correctly the s4c or si tranny has a smaller ring gear(final drive.)
so you would need
a s4c or si tranny's
~ring gear
~main shaft
(might need someone to confirm*if i'm missing anything)
s4c and j4d both have 4.4 ring gears(final drives) so you don't lose and gear multiplications.
so you would need
~ring gear
~main shaft
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DVC2004 »</TD></TR><TR><TD CLASS="quote">B16 LSD diff wont fit the s80 Type R case</TD></TR></TABLE>
Hence,
You do this,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Humping_dragon »</TD></TR><TR><TD CLASS="quote">if i remember correctly the s4c or si tranny has a smaller ring gear(final drive.)
so you would need
~ring gear
~main shaft
s4c and j4d both have 4.4 ring gears(final drives) so you don't lose and gear multiplications. </TD></TR></TABLE>
The LSD will determine what parts you order....if you use something meant for the B16, then you will have to order "B16A" tranny parts even if they are aftermarket.
Hence,
You do this,
so you would need
~ring gear
~main shaft
