obd0 tuning options
Old Dec 10, 2004 | 09:30 PM
Danethomp's Avatar
Default obd0 tuning options
not sure if this is the right forum or not. wondering what was my best option for getting my car to run better. it's a 90 integra (obd0). i've got a 94 b18c1 w/ itr pistons/rods, and a complete itr head. sittin close to 11.1:1 compression. right now i'm using a stock b16 pr3 ecu. should i just get the pr3 chipped or should i convert to obd1, hondata, or what? i do have plans of building the motor further if that makes a difference. thanks.
Old Dec 11, 2004 | 06:53 AM
Danethomp's Avatar
Default Re: obd0 tuning options (90g2ls)
ttt
Old Dec 11, 2004 | 08:25 AM
sleepin91teg's Avatar
Convert to obd1, and get hondata...thats your best bet!
Old Dec 11, 2004 | 08:31 AM
hondaguyef's Avatar
Default Re: obd0 tuning options (sleepin91teg)
You can have your PR3 socketed and use Turbo Edit. I have not dealt much with it but, if you don't want to convert to obd1 it may be your only(inexpensive) choice. If you are considering the obd1 conversion I would recommend Uberdata over Hondata anyday. Yes, you can use them for tuning your N/A car as well.
Phil
Old Dec 11, 2004 | 03:51 PM
Danethomp's Avatar
Default Re: obd0 tuning options (hondaguyef)
have u converted to obd1? i've always heard horror stories of people getting the conversion harness all f*cked up and had to totally rewire everything. if so who did u get ur conversion harness through? boomslang?
Old Dec 11, 2004 | 04:15 PM
hondaguyef's Avatar
http://www.jkobdconversionharness.com/ . Blown90hatch on here is the owner of the company and his harnesses are top quality. He gives excellent customer servie and tech support. I converted to OBD1 using his harness and I have recommended him to many others. I will trust no other harness. His design also allows for the simplest wiring of the distributor when doing the conversion.
Phil
Yuta
Jul 19, 2018 09:00 PM
blaak-crx
11
Sep 10, 2009 11:51 AM
hondachris1994
Mar 10, 2009 07:21 AM
LSVtechnologytur...
Dec 16, 2004 06:55 PM
euy
Aug 4, 2004 07:15 PM
