synchromesh, regular for friction modified
Old Dec 10, 2004 | 09:09 PM
$$broke_db8's Avatar
Default synchromesh, regular or friction modified
regular or friction modifried
Wow!! I must have read all the tread about gm synchromesh and I'm still confused about which one is better. Most of treads are saying either;
-regular is better than friction modified;
-friction modified is better than regular;
-regular is just like honda mtf;
so can someone who has experience please clear this up for me. I will most likely go with fm to hid my 2nd gear grind.
thanks
Modified by $$broke_db8 at 5:43 PM 12/11/2004
Modified by $$broke_db8 at 5:44 PM 12/11/2004
Old Dec 10, 2004 | 10:04 PM
pubestripe's Avatar
Default Re: synchromesh, regular for friction modified ($$broke_db8)
gm syncromesh is garbage IMO... i used it, and i had better luck with honda mtf... i will never put anything else in... i say get the mtf and put in some lucas tranny fluid with it... helped fix the tranny if my winter beater 89 ef.
Old Dec 10, 2004 | 10:29 PM
SlipAngleX's Avatar
i just change it with Honda MTF on a regular basis, and works just fine
Old Dec 10, 2004 | 10:58 PM
obdoneb18c1's Avatar
f.m,worked for me had a 3rd gear grind on my 150K gsr. after 60 miles the grind was gone.
Old Dec 11, 2004 | 11:06 AM
strikeback03's Avatar
I tried to get FM but none of the GM dealers around even had a part number, so I just got the regular. Got rid of my 3rd gear grind though. I have never tried Honda MTF, so I can't compare.
Old Dec 11, 2004 | 04:22 PM
Default Re: synchromesh, regular for friction modified (strikeback03)
I was about to go buy some friction modified today but decided on the regular(pennzoil 4.99).
It is much easier to go into first from a roll now, before I had to be at a complete stop. It got rid of my 2nd gear grind at low rpm (3.5k) but still grinds at 8k shift. After 1000 miles if it still grinds at 8k I'll try out some friction modified. Overall regular synchromesh is much better than honda mtf (IMO). Had honda mtf in my tranny for about 350 miles.
While doing research on sychromesh I read somewhere that you can buy just the friction modifier by itself and add it to the regular. If anyone knows about this please let me know.
Old Dec 11, 2004 | 04:44 PM
whoa its len 2's Avatar
Default Re: synchromesh, regular or friction modified ($$broke_db8)
Regular pennzoil sychromesh works fine for me. Got rid of my 2nd gear grind unless Im shifting high into the red.
Old Dec 11, 2004 | 05:26 PM
acuracy r's Avatar
Default Re: synchromesh, regular or friction modified (whoa its len 2)
pennzoil synchromesh got rid of my 3rd and 4th gear grinds
Old Dec 11, 2004 | 06:06 PM
pubestripe's Avatar
Default Re: synchromesh, regular or friction modified (acuracy r)
all of these "grinds" are coming from all of u trashing the gears... i will never ever ever ever trash a gear, even when i am at the track... our honda trannies werent made for it. if u RESPECT your tranny, than honda mtf is the absolute best for it, afterall, that is what was intended for every honda...
Old Dec 18, 2004 | 11:39 AM
eg6turb0's Avatar
Default Re: synchromesh, regular or friction modified (pubestripe)
im having a problem with third... anyone else use friction modified gm sycnhromesh ??
Old Dec 18, 2004 | 01:03 PM
Ketone's Avatar
Default Re: synchromesh, regular or friction modified (klubhed1)
get the friction modified if you are going to get gm syncromesh! I hope you know it is just a band-aide for fixing your syncro problem, it will most likely come back, but it will help for the time being! For grinding problems don't forget to check your motor mounts. I changed my mounts and my grinding stoped, just something to consider. I think motul is the best however for transmission fluid, not mtf.
Old Dec 18, 2004 | 01:18 PM
ChillOutWayne's Avatar
Default Re: synchromesh, regular or friction modified (Ketone)
regualar SM, i didnt have a grind or anything but it smoothed things up alot, goin straight from a Honda MTF fluid change too...i heard once no to use the FM cause it breaks down the seals quicker or some ****...
Old Jan 12, 2005 | 08:27 PM
mochasi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pubestripe &raquo;</TD></TR><TR><TD CLASS="quote">all of these "grinds" are coming from all of u trashing the gears... i will never ever ever ever trash a gear, even when i am at the track... our honda trannies werent made for it. if u RESPECT your tranny, than honda mtf is the absolute best for it, afterall, that is what was intended for every honda...</TD></TR></TABLE>
I have grinding issues when going to 3rd gear around 4500 rpm. I have 48,000 miles and haven't had any issues so far. I also haven't changed my transmission fluid once. I have never taken my car to the track and respect my tranny and I am the only owner. I mean I have driven it hard sometimes but rarely.
Also, for regular or friction modified.. does it matter about the temperature outside?
Old Jan 12, 2005 | 09:14 PM
wall of tvs's Avatar
Default Re: synchromesh, regular or friction modified (mochasi)
Friction modifiers in gear oil are to be used in transmissions with LSDs. Go with the regular synchromesh, imho.
WILD_WILL
Honda Civic (2006 - 2015)
20
Dec 24, 2007 06:05 AM
NorthernXposure
Apr 23, 2007 11:48 AM
RopethisS2K
May 3, 2006 10:11 PM
Jowee
May 15, 2005 01:11 PM
CM-R
Sep 24, 2001 11:15 PM
