GM Syncromesh Friction Modified users....Any Negative Long Term Effects???
I just spend a good 30 min reading through old threads about it and think I've made up my mind. I was scared to try it a while back and wanted to wait to see if anybody's tranny has fallen apart or gotten worse over time with this as apposed to Honda MTF .
I don't want to go spend $40 on GM SMFM if I should just stick to $10 worth of MTF.
Inputs are appreciated.
been using GM Synchromesh for probably close to 2 yrs now, no problems. I always used the NON Modified but then switched to Friction Modified for my last flush, dont notice any differences. but 3rd gear grind has been gone since I started using the GM, and the MTF and Redline did not help with my 3rd gear grind I used to have.
Re: (RTW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW »</TD></TR><TR><TD CLASS="quote">been using GM Synchromesh for probably close to 2 yrs now, no problems. I always used the NON Modified but then switched to Friction Modified for my last flush, dont notice any differences. but 3rd gear grind has been gone since I started using the GM, and the MTF and Redline did not help with my 3rd gear grind I used to have. </TD></TR></TABLE>
How many track events on that fluid?
New User
Re: (RTW)
Which one do you use exactly, since for the various posts I have read there seems to be various GM Synchromesh however not all are created equal.
there are 2 types, regular synchromesh and friction modified synchromesh. right now im using a mix of both, kind of like 2:1 ratio of regular to friction modified.
and I know what chris F is leading up to, but I dont have much evidence either way to tell whether it holds up under track conditions. street-wise it works great. Ill use it until it fails.
Re: GM Syncromesh Friction Modified users....Any Negative Long Term Effects??? (BlueIntegraBoy)
many S2K owners use GM synchromesh friction and have no problems. a few of these owners track their cars regularly (myself included) and it hold up fine. i change all my fluids at least once a yr regardless of mileage though
Re: GM Syncromesh Friction Modified users....Any Negative Long Term Effects??? (ITR 98 1162)
i have used gm syncromesh and it has been good to me. i do flush the tranny fluid roughly every 20k however. also, do not use the regular gm syncromesh as it is basically the same as honda mtf. the friction modified is the stuff to use.
Re: (MC_Rhett_Meister)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MC_Rhett_Meister »</TD></TR><TR><TD CLASS="quote">why would it have bad results regardless of the length of use? it helps if anything, correct?</TD></TR></TABLE>
i've heard it will break down after time
Re: (warwagon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warwagon »</TD></TR><TR><TD CLASS="quote">
i've heard it will break down after time</TD></TR></TABLE>
the tranny??
<----- semi-confused
the tranny??
Re: (nightrider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nightrider »</TD></TR><TR><TD CLASS="quote">
the tranny??
<----- semi-confused</TD></TR></TABLE>
He's referring to the fluid. It's like motor oil breaking down...
the tranny??
Re: (warwagon)
well, regular on time changes should keep it all good. you got a point though, laziness will result in damage,
search around they are around here somewhere. the regular synchromesh comes in a round container, the friction modified comes in a square container similar to a quart of motor oil. any GM stealership parts dept should have it sitting on the shelf.
Re: (RTW)
NOT Friction Modified:
http://www.acdelco.com/html/pi_vehcare_lub.htm
FM:
Not FM:
Also, Penzoil should be the same.
FM:
Not FM:
Re: (RaVAGE00)
fyi...Penzoil Synchromesh is the same as the non-FM GM Synchromesh and is available at Autozone for $5 a quart, which I believe is considerably cheaper than the GM versions.
Re: (typer_801)
i change my Honda MTF every other oil change and no problems yet...
i only do about 4 track days a month so figure about once a month. Oil always comes out gold and magnetic drain plug is reasonbly clean.
However my tranny has had a third gear grind at high rpms since i got the car three years ago.. ive put off a rebuild that long and still going strong.
:knockonwood:
:knockonwood:
