newb with a vtec timing question
Old Dec 10, 2004 | 07:29 PM
95_GSmokeR's Avatar
Default newb with a vtec timing question
i am in the process of buying a 95 gsr and i was wondering when the vtec will kick in, if anyone knows thanks in advance
also, i searched for this info and couldn't find anything, maybe we can make a list of vtec timing for all the stock heads?
maybe a dumb idea, but thanks if u can help with the info
Old Dec 10, 2004 | 07:52 PM
honda011's Avatar
Default Re: newb with a vtec timing question (95_GSmokeR)
I'm pretty sure around 5500 rpms maybe a little sooner it's in the 5 range tho
Old Dec 10, 2004 | 07:53 PM
qcktegls's Avatar
usually id say around 4500 or 5k is when it usually kicks it. test drive it and get on it to see when it kicks it
Old Dec 10, 2004 | 09:07 PM
a1320addict's Avatar
Default Re: newb with a vtec timing question (qcktegls)
stock trim....supposed to engage at 4500-4600 rpm...all motors are different though
Old Dec 10, 2004 | 09:56 PM
rovigian's Avatar
i thought its 4,400 and butterflies open at 5,800 (so thats when you usually hear it).
Old Dec 10, 2004 | 11:30 PM
b18c1995's Avatar
vtec 4400, secondaries 5750 on a b18c1
Old Dec 11, 2004 | 05:57 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (b18c1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1995 &raquo;</TD></TR><TR><TD CLASS="quote">vtec 4400, secondaries 5750 on a b18c1</TD></TR></TABLE>
^^ yessir.
And there is no "every motor is different" on this issue. That's how the ECU is programmed from the factory, and they're all the same, all B18C1's that is.
Old Dec 11, 2004 | 06:41 AM
95_GSmokeR's Avatar
Default Re: (PatrickGSR94)
thanks all for the info....
feel it at 4400, hear it at 5750, cant wait
Old Dec 11, 2004 | 05:12 PM
Default Re: (95_GSmokeR)
someones could be all screwy and totally not even have vtec if the ecu or cams are fucke dup
cloudconnected85
Oct 4, 2008 07:32 PM
tvman
Oct 31, 2005 07:08 PM
dc2_and_ef
Apr 30, 2003 09:44 AM
bearboy80
Apr 28, 2003 07:41 PM
GreenGSR
Jul 28, 2002 07:12 PM
