Tranny Casing Swap...
Old Dec 10, 2004 | 03:25 PM
mienboiracer209's Avatar
Default Tranny Casing Swap...
i was wondering if the y7 casing would fit over the y8 tranny?...the reason why i wanna swap the y7 casing is that it has all my information on my car, like my vin number and stuff like dat...any help would be better than anything...thanks...
Old Dec 10, 2004 | 08:20 PM
Jim Truett's Avatar
Default Re: Tranny Casing Swap... (mienboiracer209)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mienboiracer209 &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering if the y7 casing would fit over the y8 tranny?...the reason why i wanna swap the y7 casing is that it has all my information on my car, like my vin number and stuff like dat...any help would be better than anything...thanks...</TD></TR></TABLE>
I am 99.99% sure that the Y7 case uses smaller carrier bearings (70mm) than the Y8 tranny (80mm). There are also other bearings that would be smaller in the Y7 case, like the countershaft and mainshaft support bearings. You could put the Y8 ring gear on the Y7 diff, and use the Y8 countershaft in the Y7 trans, but is it worth it when you will have the smaller bearings?
amej8
Jun 3, 2008 01:15 PM
notstreetlegal
Apr 10, 2007 09:49 AM
95civicSirCoupe
Jun 4, 2004 05:27 AM
EK_vzla
11
Feb 2, 2004 01:07 PM
