D16Z6 head??
how can i tell if the head i got is a Z6 or not the guy i got it from has lied to me on a lot of other **** so i am just wondering if there is casting numbers or marks anywhere also if the B7 valve cover bolts and head bolts will work with this Z6 thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">p08 is stamped on the head casting if it is a z6 head.</TD></TR></TABLE>
Yep. P08 also denotes the JDM D15B head. The VX head is cast P07. The B7 valve cover bolts will not work, and I am not sure about the head bolts. You could sit the head on the block, and if you place the bolts into the head, and there is about 1" of bolt sticking up before tightening, they should be fine. If there is less than 1", or they start to bind during tightening, stop immediately and get the proper bolts.
thank you for all the info i will be checking here tonight and i am hoping for a Z6 like i was told if so its mini me time as soon as i can get this xmas out of the way thanks again
ya bit me to it theres ya answer
good news for me it is a Z6 head so i guess the intake he sent along with was a Z6 as well i guess so as soon as i get some time and money for a belt and a water pump i guess its mini me time
fireant
Feb 19, 2008 07:07 AM
