Light subs
Old Jan 2, 2002 | 09:23 PM
SleepinGSR's Avatar
Default Light subs
I want to put some bass in my 95 gsr but I dont want to add alot of weight what should I do? I heard of some sub that was designed that has a magnesium magnet or something and is like a third the weight of a normal sub anyone heard of this?
Old Jan 2, 2002 | 11:50 PM
MachAF's Avatar
Default Re: Light subs (cyb3r sn1p3r)
I havn't heard of those before..
check out IDQ's.. http://www.imagedynamicsusa.com
Very nice subs, pretty cheap some places. I think they are light, they are by no means heavy.
Old Jan 3, 2002 | 08:17 AM
crux131's Avatar
Default Re: Light subs (machaf)
May also want to look into a fiberglass enclosure....if done right, can be lighter than wooden ones, but if built pretty and flashy, often weigh more.
Old Jan 3, 2002 | 12:24 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Light subs (crux131)
BTW in order to get the box out, the STB had to come off first.
But was removeable for racing. Only took 10 minutes.
Old Jan 4, 2002 | 09:54 PM
clean's Avatar
New User
Default Re: Light subs (Mista Bone)
you didnt have to put fiberglass on the bottom dude. you posted this or someone poted this pic in my post. in the new euro lowrider they show you how to do it and i'm gonna try. you only need to glass the top
Old Jan 4, 2002 | 10:50 PM
tysf's Avatar
hey mista bone what kind of volume did a spare tire well enclosure like that give you??
im thinking of glassing my next box... i need 1.5 - 1.75 cubes
and how much does it weigh without the driver (and im assuming with an mdf top panel)
did you do the work yourself??
Old Jan 5, 2002 | 12:28 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Light subs (clean)
if you want a good seal and box to come out of car, must fiberglass the bottom.
Old Jan 5, 2002 | 12:31 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Light subs (tylerspec)
the box you see there had 2.7-2.8 cubic feet. Bow with subs/amps weight over 100 lbs. It was fun wrestling it in and out.
Yes I used MDF (anything else?) for the sides and top plates. I also braced the insides like a ****.
Best part, the resin and hardener were FREE! I used about 1.5 gallons of resin and no idea how much cloth.
Old Jan 5, 2002 | 11:45 AM
tysf's Avatar
100 pounds?? thats crazy
my old box 3/4" mdf 2.2 cubic feet with 2 jl 12W0 was around 60 pounds
i was hoping to get down to more like 25-30 pounds with a single 12 setup and a glassed box
Old Jan 5, 2002 | 07:18 PM
pagong's Avatar
have you looked into the Bazooka bass tubes? they come amplified and they can be taken out really easy! and they arent as bulky as the other boxed subs..but, this is only my opinion!!!
Old Jan 5, 2002 | 11:52 PM
GSRaCeRbOI's Avatar
Default Re: Light subs (pagong)
unless they changed their design (i dunno havent looked at the new bazooka tubes/subs) they suck... paper cones, and dont provide much hit.. my friend wanted to try his bazooka with my PPI PC21400.. needless to say.. you guys can guess the output hehe.. we replaced his paper woofer with a rockford sub..it sounds way better..
Old Jan 6, 2002 | 12:43 AM
Mista Bone's Avatar
D Tranny Guru
but mine was easy to remove for racing and overkill design for IASCA competition.
Old Jan 7, 2002 | 02:26 PM
Boughetto's Avatar
New User
Default Re: Light subs (fuzznuts)
Get the kicker free-air, no box
TypeAhhh
Audio / Security / Video
Sep 11, 2005 08:12 PM
{Powered by VIII}
May 6, 2005 07:10 AM
96lewd
Aug 20, 2004 07:15 PM
SpoonFedHatch
30
May 8, 2003 08:27 AM
lucas569
May 1, 2003 12:08 PM
