question about spoon n1
Old Dec 10, 2004 | 12:28 PM
whatcivic's Avatar
Default question about spoon n1
Does the Spoon N1 axleback for dc2 fit an em1 also?
Old Dec 10, 2004 | 12:30 PM
EkEli's Avatar
rebmem roines
Default Re: question about spoon n1 (whatcivic)
Not sure if it doesn but I think we already have enough spoon n1 owners in edmonton.
It looks so nice I want to get one.
Old Dec 10, 2004 | 12:35 PM
whatcivic's Avatar
Default Re: question about spoon n1 (EkEli)
Hahah - I know... but I found a good deal on a dc2 one so I might get it.
Old Dec 10, 2004 | 12:47 PM
whatcivic's Avatar
Default Re: question about spoon n1 (CivicTECH36)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicTECH36 &raquo;</TD></TR><TR><TD CLASS="quote">just ******* buy it and stop being a bitch and wasting bandwidth</TD></TR></TABLE>
once i get confirmation that it fits is when I'll buy it noob
Old Dec 10, 2004 | 12:52 PM
Heylookits shawn's Avatar
maybe he wants to see if it will fit and not be a waste of money? to you for being a ***
im pretty sure it will fit, but i think it will stick out a little more. or at least on hatches it does, im not sure about coupes
Old Dec 10, 2004 | 12:56 PM
Mike M's Avatar
Founding Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whatcivic &raquo;</TD></TR><TR><TD CLASS="quote">Does the Spoon N1 axleback for dc2 fit an em1 also? </TD></TR></TABLE>
NO, you would have to modify the piping.
There are 3 N1's for Civic/Integras (Not including the new SI or RSX)
1 for Integra Coupes
1 for 92-00 Civic Coupe & Sedan
1 for 92-00 Civic Hatchback
None of the 3 are interchangable without decent modification. To put one of them onto a model they aren't setup for they would all need new piping to the canister and for the Hatch the Tip is a few inches shorter so that would need to be modded too.
Save money and just get one made for your model car.
Old Dec 10, 2004 | 01:07 PM
whatcivic's Avatar
Default Re: question about spoon n1 (Mike M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike M &raquo;</TD></TR><TR><TD CLASS="quote">
Save money and just get one made for your model car. </TD></TR></TABLE>
thanks
Old Dec 12, 2004 | 10:37 AM
130R's Avatar
yeah you would have to modify it, and also the tip for the dc2 is longer than the hatchy versions
mike m = correcto
Old Dec 12, 2004 | 11:42 AM
rafael_dias's Avatar
would modifying it to fit onto a different model cause and change in performance/sound?
Old Dec 12, 2004 | 12:30 PM
whatcivic's Avatar
Default Re: (CTCH22)
Ok - had the chance to compare the two today (EM1 and DC2)... They are very close except that the EM1 has a little bit longer canister and tip. The DC2 will still fit on the EM1 but the muffler tip sits 2-3" inside the bumper (it's not flush).
Old Dec 12, 2004 | 04:15 PM
^ so do you reckon it'll fit to an Ek hatch?
Old Dec 12, 2004 | 07:58 PM
whatcivic's Avatar
the length might be ok - but not sure about position of hangers for hatch...
Old Dec 12, 2004 | 07:59 PM
whatcivic's Avatar
Default Re: (whatcivic)
... but my friend runs a ITR muffler on his hatch - he didn't have to modify anything to fit it
Old Dec 12, 2004 | 08:09 PM
yeah i think on the Ek hatch model, the pipe tends to turn straightaway, and with the dc models the pipe goes straight and then curves.. but i also heard that the tip for dc models are longer and wud stick out on eks
Old Dec 13, 2004 | 11:36 AM
Mike M's Avatar
Founding Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CTCH22 &raquo;</TD></TR><TR><TD CLASS="quote">would modifying it to fit onto a different model cause and change in performance/sound?
Possibly, depends on how they mate the new piping to the N1, size of piping they use, and also it makes a difference which way they weld it, if they weld it up with mild steel wire vs SS wire the welds will rust over time.
Old Dec 13, 2004 | 11:38 AM
Mike M's Avatar
Founding Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whatcivic &raquo;</TD></TR><TR><TD CLASS="quote">The DC2 will still fit on the EM1 but the muffler tip sits 2-3" inside the bumper (it's not flush). </TD></TR></TABLE>
Like I said you'd have to modify it, you have to extend it about 4-5 inches and change the hangers to get it to center up.
Old Dec 13, 2004 | 11:43 AM
Mike M's Avatar
Founding Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CTCH22 &raquo;</TD></TR><TR><TD CLASS="quote">^ so do you reckon it'll fit to an Ek hatch?</TD></TR></TABLE>
Civic Coupe/Sedan (EK4, EM1) won't fit, canister is too long and tip is too long, piping also needs modifying.
Same deal with the DC2 model, Canister would fit but tip needs about 2-3" taken off it and the piping needs to be modded, hangers would also most likely need aligning.
To sum it up like this, Even if you find a Spoon N1 for a cheap price, say $200, its still not worth it because to get someone to hack it up and weld it back up and use the right stuff (SS Piping, Flanges, hangers and Wire) it's going to cost you almost as much or as much as a new one that would simply bolt on. New one is about $350 with a silencer.
captain_crunch
Aug 30, 2007 11:40 AM
Petah
Apr 10, 2007 01:18 PM
xla301
Apr 11, 2005 06:59 PM
zm_dawg
Jun 16, 2004 02:06 PM
Jim80y
May 28, 2002 06:40 PM
