question about spoon n1
Re: question about spoon n1 (CivicTECH36)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicTECH36 »</TD></TR><TR><TD CLASS="quote">just ******* buy it and stop being a bitch and wasting bandwidth</TD></TR></TABLE>
once i get confirmation that it fits is when I'll buy it noob
Re: question about spoon n1 (whatcivic)
maybe he wants to see if it will fit and not be a waste of money? to you for being a ***
im pretty sure it will fit, but i think it will stick out a little more. or at least on hatches it does, im not sure about coupes
Founding Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whatcivic »</TD></TR><TR><TD CLASS="quote">Does the Spoon N1 axleback for dc2 fit an em1 also? </TD></TR></TABLE>
NO, you would have to modify the piping.
There are 3 N1's for Civic/Integras (Not including the new SI or RSX)
1 for Integra Coupes
1 for 92-00 Civic Coupe & Sedan
1 for 92-00 Civic Hatchback
None of the 3 are interchangable without decent modification. To put one of them onto a model they aren't setup for they would all need new piping to the canister and for the Hatch the Tip is a few inches shorter so that would need to be modded too.
Save money and just get one made for your model car.
Re: question about spoon n1 (Mike M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike M »</TD></TR><TR><TD CLASS="quote">
Save money and just get one made for your model car. </TD></TR></TABLE>
thanks
thanks
Re: (CTCH22)
Ok - had the chance to compare the two today (EM1 and DC2)... They are very close except that the EM1 has a little bit longer canister and tip. The DC2 will still fit on the EM1 but the muffler tip sits 2-3" inside the bumper (it's not flush).
yeah i think on the Ek hatch model, the pipe tends to turn straightaway, and with the dc models the pipe goes straight and then curves.. but i also heard that the tip for dc models are longer and wud stick out on eks
Founding Member
Re: (CTCH22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CTCH22 »</TD></TR><TR><TD CLASS="quote">would modifying it to fit onto a different model cause and change in performance/sound?
Possibly, depends on how they mate the new piping to the N1, size of piping they use, and also it makes a difference which way they weld it, if they weld it up with mild steel wire vs SS wire the welds will rust over time.
Founding Member
Re: (whatcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whatcivic »</TD></TR><TR><TD CLASS="quote">The DC2 will still fit on the EM1 but the muffler tip sits 2-3" inside the bumper (it's not flush). </TD></TR></TABLE>
Like I said you'd have to modify it, you have to extend it about 4-5 inches and change the hangers to get it to center up.
Founding Member
Re: (CTCH22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CTCH22 »</TD></TR><TR><TD CLASS="quote">^ so do you reckon it'll fit to an Ek hatch?</TD></TR></TABLE>
Civic Coupe/Sedan (EK4, EM1) won't fit, canister is too long and tip is too long, piping also needs modifying.
Same deal with the DC2 model, Canister would fit but tip needs about 2-3" taken off it and the piping needs to be modded, hangers would also most likely need aligning.
To sum it up like this, Even if you find a Spoon N1 for a cheap price, say $200, its still not worth it because to get someone to hack it up and weld it back up and use the right stuff (SS Piping, Flanges, hangers and Wire) it's going to cost you almost as much or as much as a new one that would simply bolt on. New one is about $350 with a silencer.
