converting my automatic civic to a manual...
Old Dec 10, 2004 | 09:56 AM
D15B2civic's Avatar
Default converting my automatic civic to a manual...
i have a 89 civic HB DX.. and the tranny has being pissin me off.. so.. i was plannin on swaping the tranny out to a 5 speed .. any tips on what i need other than the tranny and shift links pedal set..????
Old Dec 10, 2004 | 10:02 AM
.BigSexy's Avatar
most hood white kid
clutch master cylinder, and a bunch of other ****, not quite sure on this one.
Old Dec 10, 2004 | 10:06 AM
D15B2civic's Avatar
Default Re: (egcoupe94)
i don;t think so dude.. cuz that gen runs on a cable right..... the only think i'm un sure about is the neutral switch... VERY UNSURE.. need a honda god here..
Old Dec 10, 2004 | 10:14 AM
.BigSexy's Avatar
most hood white kid
Default Re: (D15B2civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D15B2civic &raquo;</TD></TR><TR><TD CLASS="quote">i don;t think so dude.. cuz that gen runs on a cable right..... the only think i'm un sure about is the neutral switch... VERY UNSURE.. need a honda god here..</TD></TR></TABLE>
u right...i was thinking he had a car with a hydro tranny, my bad.
Old Dec 10, 2004 | 10:51 AM
n2oef's Avatar
i just swapped mine for a manual all i did for the neutral switch is left it in park-no problems...hardest part was doin the pedals-its a little small under there....
Old Dec 14, 2004 | 09:22 AM
D15B2civic's Avatar
Default Re: (n2oef)
yea.. so what was all the things that ya need for the swap..???
Old Dec 15, 2004 | 10:25 AM
n2oef's Avatar
all i used were the pedals,clutch cable,and linkages,oh also a shifter boot and a lil sheet metal to cover the holes fron the mounting bracket for the auto shifter
Old Dec 15, 2004 | 10:42 AM
mattssi's Avatar
I would imagine that there are some mounting problems associated with the civic that was originally automatic
Old Dec 15, 2004 | 10:48 AM
fastwanabe's Avatar
Default Re: (mattssi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattssi &raquo;</TD></TR><TR><TD CLASS="quote">I would imagine that there are some mounting problems associated with the civic that was originally automatic</TD></TR></TABLE>nope no mounting problems wuth EF's. 5spd and auto had the same mounts on the frame rail unlike EG's. Everything will bolt up and you need to drill a hole for the clutch cable to go through.
Old Dec 15, 2004 | 11:23 AM
D15B2civic's Avatar
Default Re: (fastwanabe)
so nothing is wrong as far as wiring or anything like that.. i wouldn't have to mess wit the ECU..??? cuz i have most of the stuff.except for the the linkage that holds the shifter... not the shift link it self...
Old Dec 15, 2004 | 11:35 AM
.BigSexy's Avatar
most hood white kid
yes you will need a new ECU..urs is programmed for an auto tranny, not a manual tranny, you have to get an ecu for a maual tranny
Old Dec 15, 2004 | 11:43 AM
D15B2civic's Avatar
so would a ECU that came outta civic that was runnin a 5 speed be good enough..????? it'll plug right up..
Old Dec 15, 2004 | 11:49 AM
.BigSexy's Avatar
most hood white kid
it should, but dont quote me on that.
Old Dec 15, 2004 | 11:58 AM
menkio's Avatar
and LOOOKMAT RHE FYJC SEARCHASFA:DFSLIDGhA{"FIHJGS
Old Dec 15, 2004 | 05:16 PM
fastwanabe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D15B2civic &raquo;</TD></TR><TR><TD CLASS="quote">so would a ECU that came outta civic that was runnin a 5 speed be good enough..????? it'll plug right up..</TD></TR></TABLE>yes it will plug in np problem. I did this a few years ago when I had my ZC in my EF.
Old Dec 17, 2004 | 08:31 AM
n2oef's Avatar
no u dont have to drill the hole is already there....yes u can use your stock ecu but u will have a tranny code-u have to drop the rear crossmember to move the rear mount over about an inch the holes are already there but its a pain to get to the only wiring u have to do is for the neutral safety switch and for the reverse lights
Old Dec 17, 2004 | 08:43 AM
Run Hatch's Avatar
Default Re: (n2oef)
Hey i have the pedals if u need them.
Old Dec 17, 2004 | 03:56 PM
fastwanabe's Avatar
Default Re: (n2oef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n2oef &raquo;</TD></TR><TR><TD CLASS="quote">no u dont have to drill the hole is already there</TD></TR></TABLE> this would be correct IF the hole is already there.... mine didnt.
Old Dec 22, 2004 | 10:04 AM
D15B2civic's Avatar
yea.. mine dosen't have a hole eiether.. yupp yupp.. so yupp .. man.. its gonna suck having to fvck wit the wiring...
Old Dec 22, 2004 | 10:54 AM
n2oef's Avatar
that sucks mine had the hole.....guess i was lucky
Bsixteen_CRX
Oct 17, 2008 12:23 AM
wushubrian
Sep 26, 2007 11:51 AM
91_CiViC_RiDeR_DX
Nov 3, 2004 04:40 PM
Apocolipse269
Aug 27, 2004 07:01 PM
