fuel rail stud broke
When I was installing new injectos a while back one of the studs holding the fuel rail to the intake manifold broke off. Does anyone know if these studs are screwed in or cast into the manifold. If they are screwed in, are they something an acura dealer shoul have?
I had an issue with having only one usable stud when we switched the GS-R manifold for a Skunk2 manifold. I ended up using (2) M6x1.00x22mm flange bolts from the hardware store and using the stud in the middle as a placeholder.
Use a set of pliers to screw the stud out, or you can cut parallel faces onto the stud and use a wrench. Go to the hardware store and buy 6mm flange bolt of the appropriate length for your application. 22mm length might not be right for you.
haha. I ended up doing the exact same thing with my skunk2 swap (2 of the fuel rail studs broke). I felt like i was ghetto-rigging the fuel rail going to the hardware store piecing parts together to bolt it down. But now i feel much better knowing im not the only one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC »</TD></TR><TR><TD CLASS="quote">I had an issue with having only one usable stud when we switched the GS-R manifold for a Skunk2 manifold. I ended up using (2) M6x1.00x22mm flange bolts from the hardware store and using the stud in the middle as a placeholder.
Use a set of pliers to screw the stud out, or you can cut parallel faces onto the stud and use a wrench. Go to the hardware store and buy 6mm flange bolt of the appropriate length for your application. 22mm length might not be right for you.</TD></TR></TABLE>
M6x1.00x22mm for the center one and M6x1.00x35mm for the two ends on GS-R's, and they're all M6x1.00x22mm studs on the ITR manifolds.
type Gendy
Nov 13, 2007 05:41 PM
central_driver
Aug 28, 2007 12:43 AM
AzntaggeR
Apr 3, 2004 07:30 PM
...does anyone know the part number and where I can get a replacement online?
