EXHAUST FITMENT QUESTION AFTER SWAP:::EK HATCH
Old Dec 10, 2004 | 08:52 AM
jay.dee.em1's Avatar
Default EXHAUST FITMENT QUESTION AFTER SWAP:::EK HATCH
search is down right now but i have a question...
i have a 2000 hatch with an espelir jt500 exhaust system which eliminates the need for a test pipe due to the increased length of the b-pipe which fits right up to the header(assuming you all realize the EK hatches have the cat built into the header).. i still have the stock d16y7 in there but im ditching it after christmas for an LS.. i was wondering if any of you know if the LS header will bolt directly up to my exhaust without custom piping/welding being done(like i said my exhaust is currently bolted right onto the header with no test pipe needed just like the stock piping)
Old Dec 10, 2004 | 08:56 AM
mwieczorek43's Avatar
Default Re: EXHAUST FITMENT QUESTION AFTER SWAP:::EK HATCH (jay.dee.em1)
Im not sure for the EK's.
But when I swapped my EG, the E-M flange is slightly-turned.
I had to buy a resinator for an Integra to get it to bolt-up. I hope that helps!?
*edit- After re-reading your post...
You might have to cut the flange and re-weld it slightly-turned, since a resinator isn't an option. Once again... I hope that helps!?
Old Dec 10, 2004 | 08:59 AM
klungemonger's Avatar
You need to get a GSR header, it should bolt right up. The LS flange is off. I think a B16 header is too short (vertically) to clear the B18 pan, so I've heard.
Old Dec 10, 2004 | 09:05 AM
Default Re: (klungemonger)
well im going turbo in summer..until then will the dc sports header for a gsr also fit?
Old Dec 10, 2004 | 09:23 AM
ttt
Old Mar 31, 2006 | 09:07 AM
Wazup's Avatar
back from the dead... does anyone know now? (lol, 2 years later)
DrGabe
Nov 22, 2017 02:11 PM
Dan_Brutal
Dec 21, 2013 04:56 PM
ProBlackHawk
Sep 4, 2012 03:51 PM
CivicSi95
Feb 24, 2009 11:31 AM
whitelightnin
Dec 25, 2006 02:31 PM
