immobilizer question
Old Dec 9, 2004 | 11:44 PM
dayaftertomorrow's Avatar
Default immobilizer question
I have a 98 gs integra swapping with a 2001 gsr engine with ecu. The junk yard I bought the engine from did not have the ignition switch. So I just found a 2001 ignition switch with key from a the junk yard. My question is will I be able to reprogram the key to work with the ecu. Need some help. Thanks
Old Dec 10, 2004 | 12:09 AM
rovigian's Avatar
Default Re: immobilizer question (dayaftertomorrow)
Wait, I don't know if that is even possible.
A 98 would be obd2a while that ecu is obd2b. You should really just convert to obd1. Plus, wouldn't there have to be some wiring from the 2000+ ignition to the ecu, for the immobilizer to work?
Old Dec 10, 2004 | 10:31 AM
Default Re: immobilizer question (rovigian)
I have the 2001 ecu and the ignition switch with the wire .came with the motor. I live in S Cal. So I cannot use obd1. My question is can the ignition switch mix with the ecu of the different cars and still can be reprogramed the key? thanks
vtec420kingH22
Jul 26, 2006 05:13 AM
dayaftertomorrow
Dec 10, 2004 08:22 AM
eLeCtRoNSi00
Apr 16, 2004 01:17 AM
Frankie324
May 23, 2003 12:06 AM
