immobilizer question
Old Dec 9, 2004 | 11:43 PM
dayaftertomorrow's Avatar
Default immobilizer question
I have a 98 gs integra swapping with a 2001 gsr engine with ecu. The junk yard I bought the engine from did not have the ignition switch. So I just found a 2001 ignition switch with key from a the junk yard. My question is will I be able to reprogram the key to work with the ecu or vice verse. Need some help. Thanks
Old Dec 10, 2004 | 06:48 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: immobilizer question (dayaftertomorrow)
Swap it to OBD1 and use a different ECU.
Old Dec 10, 2004 | 08:22 AM
drdisco69's Avatar
Default Re: immobilizer question (JDM_Ej)
A dealer can reprogram the immobilizer to the new key, if it's all from an Integra, I don't know about mixing parts from different models.
99CivDX
Jan 28, 2015 10:55 PM
Josh1999Civic
May 15, 2014 04:52 PM
aeros
Aug 9, 2009 09:10 PM
VtecKiDD
Aug 11, 2006 06:13 PM
dayaftertomorrow
Dec 10, 2004 10:31 AM
