B16 Head - GSR Block, Use B16 HeadStuds? Re-Use ARPs?
I'm switching my shortblock over the a B18C1, I currently run a B16A with ARP Headstuds. I think that with the B16 Head I'll have to use B16 Headstuds because the GSR ones would be too long, but I'm not sure. Is it difficult to uninstall headstuds from the block, and since they are ARPs can they be re-used?
Yes you can reuse them but why would you need to take them out.. As long as your block is clean then you dont need to scrap the head or anything.. You can just remove the old head and head gasket and put the new head gasket and head back on it.. Just leave the studs there..
he needs to take them out of the b16 and put them in the b18. but can you use the b16 ones? I need to know this also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">you CANNOT use B16 head bolts/ head studs on a 1.8 bottom end
you must use GSR/ITR head bolts/ head studs</TD></TR></TABLE>
Yep. Headstuds should match up to the block your using.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beta13 »</TD></TR><TR><TD CLASS="quote">
B16 Head + GSR Block = GSR Head Studs</TD></TR></TABLE>
also, if you do GSR head on B16 block, you need B16 head studs
jonathan13
Jul 1, 2009 07:59 PM
spoonhatchblack
13
Sep 27, 2005 08:52 AM
