Problems with b20 swap HELP ASAP!
Old Dec 9, 2004 | 11:15 AM
stockSOHCeh2's Avatar
Default Problems with b20 swap HELP ASAP!
b20 in a 96 civic... rebuilt alt. fixed an unusual idle but car runs out JUICE within 2 miles of my house. the battery is good, but alternator isnt charging it. any suggestions?
lowballed for my 99 LS
Old Dec 9, 2004 | 11:16 AM
Default Re: Problems with b20 swap HELP ASAP! (B18b.ekSlip)
sumone PLZ HELP!!!
name any shops if u live in SOCAL
Old Dec 9, 2004 | 11:28 AM
Fate's Avatar
dont be cheap and buy a rebuilt alt. buy a new one
Old Dec 9, 2004 | 11:32 AM
Default Re: Problems with b20 swap HELP ASAP! (BoostedB16EG)
word!!
Old Dec 9, 2004 | 12:33 PM
Lee_Delso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedB16EG &raquo;</TD></TR><TR><TD CLASS="quote">dont be cheap and buy a rebuilt alt. buy a new one</TD></TR></TABLE>
I agree, plus you get the warrenty.
Old Dec 9, 2004 | 12:53 PM
Mario.'s Avatar
Default Re: Problems with b20 swap HELP ASAP! (Lee_Delso)
Most rebuilt alternators have a lifetime warranty... how many new alternators can hold a candle to that?
Old Dec 9, 2004 | 02:28 PM
s73's Avatar
s73
New User
did u wire it right? connections on the alt.....and did u check the connections to the fuse box (the one in under the hood).....just wondering....since u just did a swap....maybe u didn't do the wires right....
Old Dec 9, 2004 | 09:42 PM
Default Re: Problems with b20 swap HELP ASAP! (s73)
YEA bro, the doode that did it... he costumized to wire harness. he has plugs hanging around and stuff cut and etc... dams...
Old Dec 10, 2004 | 08:35 PM
s73's Avatar
s73
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18b.ekSlip &raquo;</TD></TR><TR><TD CLASS="quote">YEA bro, the doode that did it... he costumized to wire harness. he has plugs hanging around and stuff cut and etc... dams... </TD></TR></TABLE>
don't know what to tell ya then.....too many things can be hooked up wrong.....i guess the only thing u can do is check EVERYTHING.....i know how it is.....a friend of my had the same thing happen to his eg......i gues u can check the wires that is hooked up to the alt....and make sure its hooked up right.....and see if the wires are hooked up on the fuse box (the one under the hood)....there should be 2 big wires going to that fuse box...make sure they are hooked up right.....(the dumb *** that installed my friend's motor only hook up one of those wires....and left the other one hanging....and i thought that the alt was bad too....ended up it was only one (*(^*T^&*%^ wire...
oh well....good luck man
Old Dec 10, 2004 | 09:49 PM
squirrel's Avatar
Are you using the same alternator and crank pulley that came with the B20?
Some B20's come with smaller Crank pulleys than the other B series motors.
And yes, I know from experience. My B20Z came with a smaller pulley. However, my brother's jdm B20B came with a normal B series pulley.
So, if you are using the smaller crank pulley with an integra Alt. You might be burning it out.
Or, if you are using the normal pulley with the B20 alt (the one used for the smaller pulley), you might not be charging the battery enough.
Just my 2 cents.
Old Dec 10, 2004 | 11:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s73 &raquo;</TD></TR><TR><TD CLASS="quote">
don't know what to tell ya then.....too many things can be hooked up wrong.....</TD></TR></TABLE>
yea, i know,... THIS guy used speaker wire to costumize it... is it worth it to buy a new wire harness?
Old Dec 10, 2004 | 11:14 PM
Default Re: Problems with b20 swap HELP ASAP! (squirrel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by squirrel &raquo;</TD></TR><TR><TD CLASS="quote">Are you using the same alternator and crank pulley that came with the B20?
the guy that did the swap, said it came from an integra type R. and yea, it has a dif pulley. it has AEM pulley on the alt....
should i use a b20 pulley on the "integra type R" alt?
LS94tegra
Sep 27, 2009 12:13 PM
Yung Dc2
Sep 20, 2006 05:36 PM
CHIA
Dec 8, 2004 05:57 AM
Se-rv-Tak
Sep 30, 2003 09:26 PM
Wazup
Apr 29, 2003 10:37 PM
