How do i take this sensor off? o.0
Old Dec 9, 2004 | 10:39 AM
Luserkid's Avatar
Default How do i take this sensor off? o.0
I would search but i dont really know what sensor this is so i cant really search for it, sorry
Anyway these arent screws, they arent bolts, what the hell are they? Im almost ready to drill them out and replace it with regular screws, would that work? Let me know, btw its off an H22
Right behind the throttle body. Thanks.
Old Dec 9, 2004 | 10:44 AM
EVIL TYPE R's Avatar
Default Re: How do i take this sensor off? o.0 (Luserkid)
cut a notch in it with a cut off wheel, then use a flat head screw driver
Marauder's Avatar
Is that the TPS sensor on the throttle body?
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Thats your TPS sensor.
You can take a screwdriver and a hammer and spin it, theyre never on that tight. Just replace them with regular screws afterwards.
Default Re: How do i take this sensor off? o.0 (EVIL TYPE R)
or use a hack saw to cut that notch
Old Dec 9, 2004 | 12:31 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVIL TYPE R &raquo;</TD></TR><TR><TD CLASS="quote">cut a notch in it with a cut off wheel, then use a flat head screw driver</TD></TR></TABLE>
Thanks, that worked like a charm. Dremmels own
Old Dec 9, 2004 | 12:48 PM
colby's Avatar
the best way that i've found is to use a spring loaded punch. Just start on the edge
and work your way around, eventually it will loosen up and you can take it with your fingers, if you dont have a spring punch you can pick them up at sears for like $8
Old Dec 9, 2004 | 02:24 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks, that worked like a charm. Dremmels own </TD></TR></TABLE>
Before you reinstall it get some new hardware
I suggest getting 2 long studs to thread in there, and then 2 nuts. This will make it a lot easier to adjust it later on in the future. I like using the nuts because getting a screw driver back there can be a pain.
cryingsuns
Mar 20, 2011 01:13 PM
TASAuto.com
Performance
Jul 19, 2009 05:35 PM
jdmferioeg8
Sep 17, 2008 05:13 PM
kornerk12
Jun 15, 2007 04:01 AM
PrettyLakesBoy
Mar 15, 2005 03:21 PM
