quick question regarding crankshaft pulley installation
Old Dec 9, 2004 | 10:04 AM
RSVTECDC4's Avatar
Default quick question regarding crankshaft pulley installation
when installing the crankshaft pulley, what parts do i have to reuse? do i have to put my lower cover back on? or can i just put the crankshaft pulley on? also.. if i dont use the lower cover.. do i have to use the cirular metal piece that goes behind the cover? TIA
Old Dec 9, 2004 | 10:19 AM
AlxSiR7's Avatar
Default Re: quick question regarding crankshaft pulley installation (RSVTECDC4)
what? take the old one off then bolt the new one on....
Old Dec 9, 2004 | 10:31 AM
SkRiBLaH's Avatar
if you dont use the little circular metal peice on, your timing belt will "Walk" off of the cam gears. not good at all. you dont have to use the plastic cover but damn,.... why would you NOT want to?
you'd be fucked the first gravel road you went on!
Old Dec 9, 2004 | 10:48 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: quick question regarding crankshaft pulley installation (SkRiBLaH)
seriously, everything you take off, put it back on. Not doing so would be retarded. If it's damaged, replace it, but definitely do not go without any piece that was already on there in the first place.
Old Dec 9, 2004 | 09:57 PM
trellix78's Avatar
New User
Default Re: quick question regarding crankshaft pulley installation (PatrickGSR94)
put the cover back on there unless you've already stuggled to put the timing belt
on and realize you forgot to do it
Old Dec 9, 2004 | 10:01 PM
Sack Master's Avatar
Default Re: quick question regarding crankshaft pulley installation (trellix78)
Use that cover. Its there for a reason. I know from experience.
crazyhorse2011
13
Feb 15, 2016 04:27 PM
waciii
Apr 11, 2011 11:34 PM
bignosewhipper
25
Jun 13, 2008 07:49 AM
huviduc
May 23, 2006 12:31 PM
94exguy
11
Jun 1, 2005 07:55 PM
