97 3.2 TL Check Engine Light ON
My parents 3.2 TL engine light just came on last nite while they were driving home. Everything in the car is stock and it has 110k miles. It's still running and engine still idles fine. What can be wrong? Any help will be greatly appreciated
I personally do not know anything about the TL's but in my opinion it might be the light for maintanece service? To make sure all the belts are okay, etc. I could be totally wrong, but thats my 2 cents.
'97 is OBD-II so AutoXone can plug in a reader & tell you the error code. If you don't do that, it could literally be any of a hundred different things. Get the code number, sometimes they get 'creative' when they try describing what you need to fix.
there should be a fuse under that hood to reset that light, if you reset it and it doesnt come back on then you're good. If it comes back on then hook up a scanner to it.
or you could ask here.... https://honda-tech.com/zeroforum?id=17
