91 Civ hatch...1.5 overhaul...whats involved?
Old Dec 9, 2004 | 09:50 AM
teamrpmTN's Avatar
Default 91 Civ hatch...1.5 overhaul...whats involved?
I'm in the process of completely rebuilding a 1.5 to put back in a hatch. block is done, what head work has got to be done, cleaned, refaced, etc. in order to complete the overhaul?
Old Dec 9, 2004 | 09:54 AM
DaX's Avatar
DaX
Loved
Community Favorite
Just building back to stock?
Have a machine shop check for flat level surface / magnaflux the head. Also make sure you don't have any bent valves and you might want to put in new valve guides and seals.
Old Dec 9, 2004 | 10:02 AM
teamrpmTN's Avatar
Default Re: (DaX)
yes, rebuilding to stock...ny clue on how much it is to replace stock guides and seals?
Old Dec 9, 2004 | 10:50 AM
manson's Avatar
Default Re: (teamrpmTN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamrpmTN &raquo;</TD></TR><TR><TD CLASS="quote">yes, rebuilding to stock...ny clue on how much it is to replace stock guides and seals?</TD></TR></TABLE>
call around your area and find out.
Old Dec 10, 2004 | 05:10 AM
DaX's Avatar
DaX
Loved
Community Favorite
I've got a 16 valve D15B2...I've priced new guides and seals for the entire head at about $115. Labor for installing, magnafluxing, and checking for bent valves will probably be another $100-$200 [I'm guessing], depending on what shop you go to.
Old Dec 10, 2004 | 06:48 AM
Curtis2kul's Avatar
Default Re: (DaX)
on my d16a6 i got the head resurfaced, 4 new valves( all the others were good, stupid 2nd cylinder) a 3 angle valve job and the put everything back together i just had to adjust the valves for $225. but i did supply the stem seals
dominate9
Apr 14, 2020 02:10 PM
hondachris1994
Jan 19, 2007 06:24 PM
Tippyman
37
Feb 2, 2006 07:01 PM
Tippyman
Jan 30, 2006 10:39 AM
Mr. K20addict
Jan 26, 2005 01:46 PM
