To TBone: I will be trying a crankcase evac...
So I've decided to experiment with exhaust propelled crankcase evac systems on my all motor hatch. There was a debate about this in the pumping/windage losses thread a couple of weeks ago (couldn't find it). So, I will keep you all informed...any advice, suggestions are appreciated.
what kind of setup will it be? Two from the valve cover to the header?? Ive seen that done a few times. Or are u going to use the freeze plugs? Lets see the setup and some results good luck man.
All of the header mounted systems ive seen were always 2 from the valve cover, but i would def use the two freeze plugs if you weren't put vacumn on it.
You could 2 from the cover to a catchcan like mine, then pull vacuum from the top of the can where the filter usually goes, then you will help keep the oil out of the exhaust.. Make sure you use a 1 way valve or you will actually put pressure into the block.
mine just vents through the filter and has 1 way valves going in the opposit diretion , so they only blow off if crankcase pressure reaches a positive value.. For his he would just place a line where my filter is and run it to the header.
aleks77
May 23, 2007 06:53 AM
Takumi Fujiwara
Aug 23, 2005 08:34 PM
