Smell Gas???
When my car is started i smell a strong sense of gas, but when im driving i dont smell it.. Strange huh??...When im parked with the car on i smell it
What could it be>??
What could it be>??
yea i suck at installing injectors and i always pinch an o-ring. fuel also evaporates pretty fast so it may not leave a puddle or anything. i'd get it checked out ASAP. when my fuel rail was leaking, i couldnt smell with when driving, but when i was idling or just sitting in my car, i could really smell it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">yea i suck at installing injectors and i always pinch an o-ring. fuel also evaporates pretty fast so it may not leave a puddle or anything. i'd get it checked out ASAP. when my fuel rail was leaking, i couldnt smell with when driving, but when i was idling or just sitting in my car, i could really smell it.</TD></TR></TABLE>
yea same problem.. is there anyway i can do it myself.. i dont feel like paying anyone..Is it a e-z fix??
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Did you **** with the hose going from the fuel filter to the fuel rail? If you did those washers need to be replaced or some liquid gasket needs to be thrown on em. I'm just thinking of that cause the fuel filter is so close to the air inlets for the fresh air mode on your heater... But yeah get this **** fixed asap... Otherwise KABOOOM!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFanatic708 »</TD></TR><TR><TD CLASS="quote">Did you **** with the hose going from the fuel filter to the fuel rail? If you did those washers need to be replaced or some liquid gasket needs to be thrown on em. I'm just thinking of that cause the fuel filter is so close to the air inlets for the fresh air mode on your heater... But yeah get this **** fixed asap... Otherwise KABOOOM!!!
Damn u scaring me, i dont want my car to blow up at the gastation or just burst in flames.. i know where the fuel rail is.. Where is the fuel filter.. I will fix it myself 2morrow morning..Pictures willl help
-Randy
</TD></TR></TABLE>Damn u scaring me, i dont want my car to blow up at the gastation or just burst in flames.. i know where the fuel rail is.. Where is the fuel filter.. I will fix it myself 2morrow morning..Pictures willl help
-Randy
i did a search, found no pics.. if u can, find one and post it up for me
-thanks
ps. or show where it might be leaking at, so i can have a good idea
-thanks
is your car stuttering at all? if u got a leak like that, the pressure would be a bit off. my line popped cus the intake was rubbing the line, and my gas shot out like a **** fog system! and of course, the car wouldnt run, jb weld fixed it, $5!!!
possible fuel connections that can be leaking:
- fuel tank outlet from tank (under rear seat)
- fuel inlet (return line from fuel rail)
- fuel filter inlet/outlet
- fuel rail inlet
- between injectors and fuel rail
- between fuel pressure regulator and fuel rail
- between fuel pressure regulator and return line
if you don't know what these things are, pick up a Haynes manual from your local auto store (~$15 at most). it'll show you pictures and everything
- fuel rail inlet
well i just looked at and i think its in front of the car.. 1 of the injectors had moisture to it.. the last 1 on the right.. and my car is acting dumb.. Like reving by itself.. rpms going up and down by itself.. i checked the fuel line, its fine.. I have a 90-93 honda accord manuel.. would that help??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">- between injectors and fuel rail
Couldn't it also leak between the injectors and the intake manifold?
here is a picture of where to find your fuel filter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PandaHatch »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>(if the owner of this car/picture would like me to remove it please let me know, sorry in advance if it's a problem)
In the second picture, the fuel filter is just to the left of the throttle body.
Hope this helps.
</TD></TR></TABLE>(if the owner of this car/picture would like me to remove it please let me know, sorry in advance if it's a problem)In the second picture, the fuel filter is just to the left of the throttle body.
Hope this helps.
jaydm ferio
12
Jan 20, 2005 11:47 PM
AEGEAN
Dec 30, 2002 07:33 PM
