Rotor screw
Old Dec 8, 2004 | 08:44 PM
BoostedEF's Avatar
Default Rotor screw
Im having a problem with the dis. rotor screw . Its either backing out or breaking in half on the shaft. The motor is a turbo first gen b16 using a jdm dis. Theres no wobble on the shaft & no odd noise when it spins . The only noise it has is when its on the car it sounds like the rotor is scraping the cap . This happen to any body ? My last resort is to buy a new one from Dis King
Old Dec 9, 2004 | 08:00 AM
thatbluecrx's Avatar
Default Re: Rotor screw (BoostedEF)
lotsa locktite
Old Dec 9, 2004 | 08:27 AM
Dan GSR's Avatar
if it sounds like the rotor is scraping, check to see if the shaft in the distributor is bent
shamless plug, I have a distributor for sale
https://honda-tech.com/zerothread?id=1072215
located on long island, if you want to pick up
Old Dec 10, 2004 | 09:44 AM
BoostedEF's Avatar
Default Re: Rotor screw (Dan GSR)
thanx but I need a obdo dis.
Tasp72
Feb 16, 2016 04:50 PM
Extreez
Jan 3, 2007 04:33 PM
bleedblue94
Jan 7, 2006 10:08 PM
Rory Breaker
Mar 3, 2003 02:25 PM
91HATCH
10
May 3, 2002 12:40 AM
