torque specs
Old Jan 2, 2002 | 02:38 PM
S13 slide's Avatar
Default torque specs
alright im installing my pistons in my block and i have arp rod bolts, now the instructions that came w. the rod bolt says to torque the rod bolts to 40lbs then losen them and repeat 2 more times, but in the helms it says to torque the bolts to 23lbs. so which do i torque them to? thanks alot oh since this is my first motor im building, any tips for assembly that would help me or things that i should watch out for? thanks
Old Jan 2, 2002 | 03:26 PM
JDM_DOHC_SiR's Avatar
New User
Default Re: torque specs (bobo)
Go buy what ARP recommends..They do make the bolts
Old Jan 8, 2002 | 09:29 AM
GM2000ITR's Avatar
New User
I would read the instructions more carefully. Example: Eagle rods come w/ ARP rod bolts...torque spec = 28 ft.-lbs. Also, remember that stock rods are not as strong as, say, Eagles, and may not require/be able to handle 40 ft.-lbs. Good Luck!!
b20vtech
Apr 20, 2007 08:51 AM
2phast
Jun 25, 2005 08:41 PM
EK FLY
Dec 31, 2004 06:18 AM
nortrop
Aug 16, 2004 06:03 AM
b20ek
Jun 15, 2003 07:02 PM
