5v wire on TPS
Old Dec 8, 2004 | 08:04 PM
ferio 95's Avatar
Default 5v wire on TPS
My 5v yellow wire on my tps is reading high numbers like 11-12 volts at idle. Why? and what can i do to fix
Old Dec 9, 2004 | 11:49 AM
ferio 95's Avatar
Default Re: 5v wire on TPS (ferio 95)
Old Dec 9, 2004 | 07:07 PM
93_hatch's Avatar
dude ur pcm might be f ed up its suppose to regulate that
Old Dec 9, 2004 | 07:38 PM
bonestockls's Avatar
Default Re: 5v wire on TPS (93_hatch)
could be shorted to voltage somewhere in the harness, being that those numbers are so close to battery voltage. Try cutting the wire right at the ecu connector on the pine for tps reference and also at the tps plug and running a different wire and see what your numbers look like, if they are still high, your ecu is phucked. Also a poor ecu ground will skew your reference voltages upwards....but your car would run like complete crap if that were the case
Old Dec 9, 2004 | 09:55 PM
ferio 95's Avatar
pcm?
Old Dec 9, 2004 | 10:13 PM
93_hatch's Avatar
power control module
wouldnt that be a short to power thou? so other things would be effected also if it was a pcm ground all the sensor would be messed up
Old Dec 10, 2004 | 09:16 AM
ferio 95's Avatar
well i checked the 5v wire on my map sensor and it was also showing battery voltage
f20b_guy
Nov 3, 2010 11:55 AM
hoggy
Dec 16, 2003 09:04 AM
This One
Feb 2, 2003 04:20 AM
