GSR Block vs B16 Block....need advice
Old Dec 8, 2004 | 05:41 PM
EGinNY's Avatar
Default GSR Block vs B16 Block....need advice
Well ive been debating this for a few weeks now and i cant decide.....
I had a little incident with my original b16a block.....https://honda-tech.com/zerothread?id=1046872
I have the option now to buy a JDM B16a block Built by RPM in NY (from a friend),
I know it has JE pistons & eagle rods. it was also cleaned up (milled,honed,sleeved??)
It was built for high compression & he only had it in his car a few months and was never beat on(pulled it for b20vtec). He also has all receipts...
He wants "around" $1000
OR
Ive been on the search for a GSR block (see sig) but can not seem to find one
I remember a friends old hatch with a poor mans R and it pulled hard
Should i go with the b16 or wait for a gsr??
The block will be going on a B16a head with ITR cams,ITR intake mani. and TB.
Also what head gasket would be recomended for both setups??
Thanks for any input in advance
Modified by EGinNY at 10:30 PM 12/8/2004
Old Dec 8, 2004 | 07:26 PM
nub.96ek's Avatar
Default Re: GSR Block vs B16 Block....need advice (EGinNY)
i would go with the b18 block... as for the head gasket - use a stock one [if you want it to bump ur comperssion, just take a layer out of it]
Old Dec 8, 2004 | 07:30 PM
DRIVENRacing's Avatar
gsr block = but if the b16 block is built, and your doing na, they can handdle alot more compression... my 2 cents.. gl
Old Dec 8, 2004 | 10:08 PM
nighttrain33's Avatar
Default Re: (TurboHybridEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboHybridEG6 &raquo;</TD></TR><TR><TD CLASS="quote">if the b16 block is built, and your doing na, they can handdle alot more compression... my 2 cents.. gl </TD></TR></TABLE>
The B16 block is generally more stable in FI applications because of its shorter stoke, though if built correctly, they should both be able to handle a good amount of boost.
-Shane
Old Dec 8, 2004 | 10:54 PM
Br1anPham's Avatar
Default Re: GSR Block vs B16 Block....need advice (NUB-96EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NUB-96EK &raquo;</TD></TR><TR><TD CLASS="quote">i would go with the b18 block... as for the head gasket - use a stock one [if you want it to bump ur comperssion, just take a layer out of it]</TD></TR></TABLE>
are you sure its salf to just take a layer out? o.0?
jowiegsr
Aug 27, 2007 07:47 PM
Herzeleid
13
Mar 21, 2007 10:33 AM
xDicktonesx
Aug 6, 2005 09:04 AM
SiR Kid
Jun 26, 2003 09:20 AM
93civEJ1
Feb 18, 2003 10:50 AM
