trouble removing spark plugs
Old Dec 8, 2004 | 04:54 PM
komat's Avatar
Default trouble removing spark plugs
im having problems with removing one of my spark plugs on my hb cx. any tips on loosen it up. dont want to put too much force into it or it might break...
also where is the fuse for the fuel injector
i want to do a compression test on the motor
hmm i just notice i posted in the wrong forum section:-/
Modified by komat at 6:15 PM 12/8/2004
Old Dec 8, 2004 | 04:56 PM
EL Vap133's Avatar
Default Re: trouble removing spark plugs (komat)
Lefty loosy, right tighty.
Did you tighten them too much when you installed them?
MR5sARECOOL's Avatar
try looking here https://honda-tech.com/zerosearch
Old Dec 8, 2004 | 04:57 PM
komat's Avatar
Default Re: trouble removing spark plugs (MR5sARECOOL)
alrdy try searching.... nothing came up
unless imissed it
the person that own the car before i bought let some services shop changed it
Old Dec 8, 2004 | 05:05 PM
turbotommy's Avatar
why not spray in a little liquid wrench...
try constant pressure on whichever tool your using <--- always works for me on ANY bolt. it might be a bitch but you'll be suprised how one minute of pulling on a wrench breaks a bolt loose faster than yanking on that same wrench for a couple seconds.
Old Dec 8, 2004 | 05:19 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: trouble removing spark plugs (turbotommy)
Be sure to use antisieze when you re-install them.
Old Dec 8, 2004 | 05:20 PM
komat's Avatar
someone told me to use a torque wrench will that be safe?
Old Dec 8, 2004 | 05:24 PM
komat's Avatar
Default Re: (LSVTEC 91 Civic)
sorry i wasnt clear enough
use a torque wrench to remove the plugs
i still cant get it out with a ratchet
Old Dec 8, 2004 | 05:25 PM
turbotommy's Avatar
Default Re: (komat)
i torque wrench or a jesus-bar <----they both create more "torque" than you can on the sp...
its a longer wrench than what your using...a 2' bar over your simple ratchet wrench is the same thing. seriously though...try the constant pressure over a longer period of time. it works
Old Dec 8, 2004 | 05:27 PM
komat's Avatar
Default Re: (turbotommy)
i did for 40sec wouldnt budge a bit
going to warm up the engine and try it
Old Dec 8, 2004 | 05:29 PM
Banned
Default Re: (komat)
Warming up will only expand the metal.. Get a can of PB Blaster (**** works) and let it soak in the spark plug threads.
Old Dec 8, 2004 | 05:40 PM
turbotommy's Avatar
do you have any metal bars that your ratchet wrench will fit in? something like a jack bar from your floor jack? ****..i've used a vacumm tube from my dust devil. the wonders of plastic huh..
slide the bar over the wrench and start apply *** much pressure as u can.
Old Dec 8, 2004 | 06:10 PM
komat's Avatar
after warming up the motor it came out easily
Old Dec 8, 2004 | 06:11 PM
turbotommy's Avatar
Default Re: (komat)
wtf?!?! thats wierd...
cool though
Old Dec 8, 2004 | 07:09 PM
crazyslowhatch's Avatar
PB Blaster kicks ***
Ruy
May 14, 2013 05:43 PM
1nsoman1ac
70
May 31, 2009 09:11 AM
RTW DC2R
Jan 16, 2005 11:02 AM
djnikko
Apr 3, 2004 04:31 AM
rastropovitch
Feb 25, 2003 02:22 PM
