Fuse for instrument cluster keeps blowing, short?
Old Dec 8, 2004 | 02:25 PM
plusONE DC2's Avatar
Default Fuse for instrument cluster keeps blowing, short?
i keep blowing out the instrument/dash fuses .could it be a bad ground or maybe a starter or battery surge any one help please.
Old Dec 8, 2004 | 02:32 PM
93egSIboi's Avatar
Default Re: Fuse for instrument cluster keeps blowing, short? (Kaoticeg6)
im not sure why yours is blowing, but on my 93 hatch i had my deck stolen a little while back. the wires were left exposed and i was too lazy to tape em up or get a new deck so i just left em. one night i was driving to work and one of the wires touched some metal or another wire in my dash. there was a big *** spark/flash that lit up my whole dash inside and all my lights went out. headlights, tailights, parking lights, instrument panel lights, and dash lights. i guess i blew my instrument panel/dash fuse. i replaced the fuse with a backup and hasn't happened since though.
Old Dec 8, 2004 | 02:41 PM
jlacoy82's Avatar
71.192.16.183
Have you done any work in your dash? Stereo, alarm? Anything else?
Old Dec 8, 2004 | 03:33 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
If I read this correctly this would be the #15 fuse. A 10a "back-up light" fuse? So Spedo, tach etc. don't work. Along with the directionals correct?
Old Dec 8, 2004 | 05:52 PM
93egSIboi's Avatar
Default Re: Fuse for instrument cluster keeps blowing, short? (HondaFanatic708)
yup thats the one
Old Dec 9, 2004 | 01:38 PM
Default Re: Fuse for instrument cluster keeps blowing, short? (93egSIboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egSIboi &raquo;</TD></TR><TR><TD CLASS="quote">yup thats the one
</TD></TR></TABLE> Mine blows on a more regular basis than it should. I believe my temp guage is shot, however I have not verified if it is just a short in the wire yet but I know it isn't the guage sending unit. I don't think my alternator is the problem but I have a 150a max output, 90a at idle alternator. Maybe that additional output is ****** with mine. Hopefully I will feigure this out so I can help. I don't think it could be in the cable reel since wipers and headlights still work along with the horn. Someone correct me if they know what is actually is. BTW I have a Viper 2way alarm and an aftermarket stereo as well. However I am very OCD when it comes to wiring so I know there isn't anything loose on that end that would be causing this... We'll all work through this **** together...
Old Dec 9, 2004 | 02:02 PM
pwr2lbs's Avatar
If your fuse blows you either have a short to ground or a circuit that is drawing more amperage than the fuse is set for. If the fuse blows right away it is usually a short to ground. shorts are hard to find, but check with the wiring diagram and start disconecting wires in the circuit until the problem goes away. The best way to see if the short and or draw has gone away is to have a amperage meter connected to the fuse block. However do not keep the amperage meter connected the entire time or wires will start melting. If you dont have an amperage meter you will end up buying a lot of fuses and installing them every time that you disconect a wire or a consumer in the circuit.
Old Dec 9, 2004 | 05:38 PM
Default Re: Fuse for instrument cluster keeps blowing, short? (pwr2lbs)
Yea i just installed a gsr cluster but everything was working fine for about 2 weeks untill yesterday i left work and all of a sudden the light cuts off.When i installed the cluster i taped up the wires pretty good.made sure no wires was touching anything
Modified by Kaoticeg6 at 8:23 PM 12/9/2004
Old Dec 10, 2004 | 05:10 PM
Problem solved i found a wire expose from when i installed my city lights on the JDM headlights. Thanks for your help guys
NarlyStarz
Nov 15, 2008 05:07 PM
Jas0nEK
Jul 12, 2008 11:35 AM
accorkie
Sep 16, 2005 12:23 PM
jnet
Dec 20, 2004 05:31 PM
