emissions info
Old Dec 8, 2004 | 01:03 PM
AFTERZERO's Avatar
Default emissions info
I need to take my car for emssions this month, but Im not sure if it will pass. I currently have a stock obd1 92b16 on a 99 civic. The car is throwing a knock sensor code. Currently I am running a 99 civic si ecu on it, and the engine light stays on all the time I was wondering what can I do to get rid off the engine light, if I use a obd2- obd1 jumper harness and a stock obd1 ecu, will I able to pass? Is there anyway to bypass the knock sensor code? any info would be appreciated....I tried doing a search, but I coulnt find any info. Here in Chicago all they do is put the sniffer no dyno cause the car is too low. Thanx
p.s all I have is intake header exhaust and hi flow cat.
Old Dec 8, 2004 | 01:54 PM
civiccpedx's Avatar
Default Re: emissions info (crisparra)
well where i am from you can only put a engine that is the same year as the car or newer. i don't know if they check that, but that in-and-of itself is illegal. Also if you are throwing codes they prolly wont pass you, but i am not to sure. Anyone else?
bump
Old Dec 8, 2004 | 06:45 PM
AFTERZERO's Avatar
Default Re: emissions info (civiccpedx)
Im only throwing one code, and thats knock sensor! Im gonna have my boy fix it hopefully this will let me pass...
Old Dec 8, 2004 | 08:30 PM
f1z1c's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crisparra &raquo;</TD></TR><TR><TD CLASS="quote"> ............
p.s all I have is intake header exhaust and hi flow cat.</TD></TR></TABLE>
Do you have visual inspection in your state, and if so, is your gear going to pass that?
Old Dec 10, 2004 | 12:44 PM
AFTERZERO's Avatar
Default Re: emissions info (f1z1c)
No visual I already went once, and all they did was put the sniffer on.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f1z1c &raquo;</TD></TR><TR><TD CLASS="quote">
Do you have visual inspection in your state, and if so, is your gear going to pass that?</TD></TR></TABLE>
Hatch Man
12
Nov 27, 2017 01:59 PM
mck26
Jan 8, 2006 03:33 PM
mp5o
Oct 16, 2005 04:07 AM
tek_civic
Aug 8, 2003 03:36 PM
