JDM vs USDM Compression Ratio
Quick question.
Assuming the following:
(92-96)
JDM H22A's CR is 10.6:1
USDM H22A* CR is 10:1
Am I correct so far ?
If so, I would think the only thing bumping the compression slightly on the JDM motor are slightly higher compression pistons? Or is there <U>anything</U> else? (Cam profiles maybe?)
Thanks!
Si
(To cut to the chase, I want to know if putting USDM pistons/rings in my H22A will bring compression back to 10:1)
(92-96)
Thanks!
Si
AndyD
Jan 6, 2003 07:07 AM
