Condensaton in head lights
Old Dec 8, 2004 | 10:18 AM
jay_96teg's Avatar
Default Condensaton in head lights
What should i do to get the condensation out of my headlights??? The vent tube is not cloged and the lights never dry out, they constantly have water in them, even if it does not rain for 2 weeks. What should i try to dry them out and keep them dry...
Old Dec 8, 2004 | 10:49 AM
timmy8151's Avatar
Default Re: Condensaton in head lights (jay_96teg)
There's problem a crack in the seal of your headlights. You have 2 options for repairing them.
1) Bake your headlights in the oven and pull the lens off. Clean the inside and reseal the lens with some sealant. Also, check other areas of the headlights for cracks and fill with epoxy
2) Some have also had success with drilling a small hole in the headlight to allow with drainage of the water.
Old Dec 8, 2004 | 11:01 AM
GSRRacer95's Avatar
Default Re: Condensaton in head lights (timmy8151)
I drilled my mine.
Old Dec 9, 2004 | 08:57 PM
jay_96teg's Avatar
Default Re: Condensaton in head lights (GSRRacer95)
does drilling a hole really help?
should it be drilled in the bottom or the top??
is it to drain the water or just to provice a vent, because my head lights do have a vent and it is not cloged..
wtf???
Old Dec 12, 2004 | 08:56 PM
jay_96teg's Avatar
help on the headlights!!!
Old Dec 12, 2004 | 09:00 PM
RidinStock's Avatar
bump for an answer, i have hella water stuck in my headlights/taillights/bumper lenses
Old Dec 12, 2004 | 09:19 PM
SHystrdyGSRtdy's Avatar
Default Re: Condensaton in head lights (RidinStock)
headlights... take them apart, clean them, make them dry, put them back together, silicon the **** outta them...
taillights... get as much water out as possible, use a blow dryer... but a new heavy duty gasket... search on ht... some guy was selling them a while back, not sure if he's doing it anymore... like rajed or something like that
Old Dec 12, 2004 | 10:51 PM
jay_96teg's Avatar
Default Re: Condensaton in head lights (SHystrdyGSRtdy)
is it to drain the water or just to provide a vent, because my head lights do have a vent and it is not cloged..
wtf???
Old Dec 12, 2004 | 11:08 PM
i wouldn't drill holes.. but that's just me
Old Dec 13, 2004 | 12:47 AM
Das Nuge's Avatar
Bump, I could use some help too.
My front right two lights are foggy and my right tailight is foggy too.
Old Dec 13, 2004 | 08:09 AM
sleevedgsr's Avatar
Woot there is some adheasive spray you can buy that clears out your headlights of moisture! Its by eagle one just came out!
Old Dec 13, 2004 | 09:41 AM
marsbike's Avatar
From: Salt Lake City, Chicago at heart, UT or IL, USA
Default Re: Condensaton in head lights (boosted95teg)
check out this thread! https://honda-tech.com/zerothread?id=1083854
Old Dec 13, 2004 | 09:43 AM
HONDA RR's Avatar
Buy another headlight without any cracks.
Old Dec 13, 2004 | 09:47 AM
marsbike's Avatar
Default Re: Condensaton in head lights (MITSUBA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MITSUBA &raquo;</TD></TR><TR><TD CLASS="quote">Buy another headlight without any cracks. </TD></TR></TABLE>
Dude, that's expensive as hell. It's about 260 from robearracing.com, which is the cheapest place I've found for headlights. why not just take a couple of hours and diy right the first time.
Old Dec 13, 2004 | 07:13 PM
RidinStock's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted95teg &raquo;</TD></TR><TR><TD CLASS="quote">Woot there is some adheasive spray you can buy that clears out your headlights of moisture! Its by eagle one just came out! </TD></TR></TABLE>
Anyone have any more info on this? Definitely sounds nice. As for now, I'm gonna try using the blowdryer and looking for that heavy duty gasket.
Old Dec 14, 2004 | 09:57 PM
jay_96teg's Avatar
I'm gunna try to take them apart to clean. (norm and high beam)
I will let you know how it turns out.
K i l l a B e e.
Aug 7, 2007 08:48 PM
TheMoogly
Honda Civic (2001 - 2005)
11
May 13, 2007 11:25 AM
rasinhell
Feb 17, 2005 04:35 AM
Scartissue
Nov 12, 2004 11:01 AM
white95
Feb 7, 2003 05:41 PM
