94 civic cx with 96 or up cluster
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">will a 96 or up civic cluster fit directly into my 94 hb cx??i dont want to do any custom mounts or custom fitting</TD></TR></TABLE>
It's not a direct swap if that's what you're wondering. The mounting points are different, as well as the wiring.
yea the wiring i knew that
thats easy to do
what cluster will be the easier to do a direct swap?? 92-95 ex/si ?
thats easy to do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">yea the wiring i knew that
thats easy to do
what cluster will be the easier to do a direct swap?? 92-95 ex/si ?</TD></TR></TABLE>
Well yeah, a cluster from a 92-95 civic would be the easiest to swap into your 94 cx.
thats easy to do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">alrite thanks
having a hard time finding one with a tach without the automatic gear letters on the right</TD></TR></TABLE>
There's usually people selling them in the classifieds forum.
What is wrong with some custom brackets. Liek the DC ITR/integ cluster in the EK civic. pretty simple its just plumber straps and you screw them in and adjust the cluster and put the bezel back in.
They are custom brackets. You have to 'customize' your own. I tried putting a JDM ITR cluster into my 92 hatch and the mounting points are close, but I would need to trim the dash bezel as the cover slants the opposite way compared to the stock Civic cluster.
smileydub
Feb 21, 2010 07:51 AM
dragonjay006
Aug 30, 2005 05:28 PM
