full race + autometer need suggestions
Old Dec 7, 2004 | 04:10 PM
adictionbass's Avatar
Default full race + autometer need suggestions
whats up guys. Just received the full race manifold i bought from Mpir3 I pulled out the autometer egt gauge i picked up a couple weeks ago and ran into a problem. The threded bung welded on the manifold isnt the same size as the nut on the egt probe. Any suggestions for me?
Heres some pics... really bad camera. TIA for any help
Old Dec 7, 2004 | 04:19 PM
hondaguyef's Avatar
Default Re: full race + autometer need suggestions (adictionbass)
Go to the local hardware store and get an adapter. What pitch is the bung and what pitch is the nut? I may be able to help.(i.e. access to millions of adapters like this).
Phil
Old Dec 7, 2004 | 04:23 PM
msmotorsports's Avatar
Just out of curiosity. Why is the EGT on the #3 cylinder port and not in the collector where all cylinders meet? Were you planning to run an EGT sensor for all 4 cylinders?
Old Dec 7, 2004 | 04:28 PM
Default Re: full race + autometer need suggestions (hondaguyef)
this is the best i can do right now. The bottom threads are 1/8" NPT which is what is supposed to go into the manifold and the nut on the prob threads onto the top threads. The threads that are on the manifold look exactly the same as the 1/8" NPT.
Old Dec 7, 2004 | 04:30 PM
msmotorsports, ive have asked the same question, y put it on the number 3 cylinder. The best answer i have been given is that due to its location, cyl 3 runs the hottest, so you get the reading of the hottest cylinder.
Old Dec 7, 2004 | 04:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass &raquo;</TD></TR><TR><TD CLASS="quote">msmotorsports, ive have asked the same question, y put it on the number 3 cylinder. The best answer i have been given is that due to its location, cyl 3 runs the hottest, so you get the reading of the hottest cylinder.</TD></TR></TABLE>
Makes sense but can posssibly lead to false readings. Hopefully all works out well.
Old Dec 7, 2004 | 04:35 PM
Default Re: full race + autometer need suggestions (msmotorsports)
i havent heard anyone on here having a problem with it, and i think thats the way 90+% have them done
Old Dec 7, 2004 | 04:36 PM
BACK ON TOPIC
bomber's Avatar
Yep, #3 runs the hottest so its the 'worst case scenario' so to speak...
Old Dec 7, 2004 | 04:48 PM
hondaguyef's Avatar
Default Re: full race + autometer need suggestions (bomber)
I'll see what I can do tomorrow. The nut is 6AN I imagine? So, I'll look for a 6AN male to 1/8 npt female adapter.
Phil
Old Dec 7, 2004 | 04:52 PM
ummm sounds like a good guess....
Old Dec 7, 2004 | 04:58 PM
how big of a deal would it be to have to use an adaptor which would pull the probe out of the runner (1/2" maybe)?
Old Dec 7, 2004 | 05:46 PM
Old Dec 8, 2004 | 07:00 PM
bump
Old Dec 8, 2004 | 08:27 PM
RMF
Guest
Posts: n/a
What size wrench fits the fitting? Because it looks like 1/4 pipe to me.If that is #6
then that is 1/4 pipe
Old Dec 8, 2004 | 08:40 PM
Default Re: full race + autometer need suggestions (RMF)
the size of the one on the probe is 16mm. The nut part on the adapter is 14 mm
platinum00
Dec 23, 2004 08:21 AM
adictionbass
Welding / Fabrication
Dec 13, 2004 10:03 AM
playAho
Jun 19, 2004 06:35 PM
siis2fast
May 15, 2004 11:14 PM
boredracer408
Dec 6, 2003 08:46 AM
