oil found on spark plug
I have a turbo b16a1 and I havn't been able to build full boost latley, so I pulled the spark plugs and found oil on one of the spark plugs and oil at the base of the spark plug. What could be the problem?
wow... has a turbo setup but didn't know that one... WOW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">wow... has a turbo setup but didn't know that one... WOW</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shaguar47 »</TD></TR><TR><TD CLASS="quote">spark plug tube seals need to be replaced</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integra_gs »</TD></TR><TR><TD CLASS="quote">those are called the valve seals... there are 4 of them... and its connected to the valve cover...</TD></TR></TABLE>
Actually valve seals are in your cylinder head and have nothing to do with spark plugs OR oil on them for that matter. What you need to replace is<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkipMic2006 »</TD></TR><TR><TD CLASS="quote">yeah a rubber gorments ..like a gasket for the valve cover </TD></TR></TABLE>
the spark plug grommets for the valve cover
