Check Engine Light NO Codes Bogging At 4K
Old Dec 7, 2004 | 11:32 AM
spoonhatchblack's Avatar
Default Check Engine Light NO Codes Bogging At 4K
Can You guys Give me A Hand.
I Got a 92 Hatch Si Stock w/D16z6 Motor.
I Had a Problem Starting the Car at First.
To Find out why it did not start was the Tranny Ground (Located Engine Bay by the Hydraulic Clutch Line)
Now It Starts up Fine.
The problem is that the Check Engine Light Stays on.
Jumped it and No Codes Flashes??? "0" Codes. With the Engine Light ON.
Also it will not Rev Past 4000 rpm??? (it boggs out really bad when you rev it)
At the Same Time the Exhaust Smoke From the Tail Pipe is Seem like its Running So Rich That it Burn your eyes.
I Tried to Troubleshoot it as much i can Think. Main Relay, Fuses, Fuel Pump, Ecu, Grounds, Even Disconecting the Viper Car Alarm, Checking the Engine Hardness, Battery Thats about all that i've done.
Can someone out there Give me a Big Hand On This.
I would Appreciate It Very Much.
Old Dec 7, 2004 | 11:39 AM
Street Ghost's Avatar
Default Re: Check Engine Light NO Codes Bogging At 4K (spoonhatchblack)
Your car is in LIMP mode.. bad ECU.
Old Dec 7, 2004 | 12:19 PM
Burke's Avatar
Banned
Default Re: Check Engine Light NO Codes Bogging At 4K (_Edge.ONE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _Edge.ONE &raquo;</TD></TR><TR><TD CLASS="quote">Your car is in LIMP mode.. bad ECU.</TD></TR></TABLE>
try a buddie's ecu. as long as its obd1 it should start
Old Dec 7, 2004 | 12:23 PM
BauleyCivic's Avatar
Risky Business
Default Re: Check Engine Light NO Codes Bogging At 4K (Burke)
Yup...constant CEL means its an ECU problem
Old Dec 7, 2004 | 01:29 PM
alotawatts's Avatar
Default Re: Check Engine Light NO Codes Bogging At 4K (BauleyCivic)
Check timing too ?
Old Dec 8, 2004 | 03:50 PM
Default Re: Check Engine Light NO Codes Bogging At 4K (alotawatts)
Thanks For The Help.
Any other ideas before i Try The ECU LIMP!
Anything Any Other Ideas???
Old Dec 8, 2004 | 03:56 PM
DAguyLS's Avatar
how your dizzy looking?
Old Dec 9, 2004 | 09:19 AM
Default Re: (slamdcivic)
Just Checked the ECU. It works Fine. Used A Buddys Stock P28 and still same Thing. Flashing Check Light.
I Dought it the Dizzy.
Any Other Assist Guys??
Im Thinking Its either a False Relay or a bad Connection???
Old Dec 9, 2004 | 10:20 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonhatchblack &raquo;</TD></TR><TR><TD CLASS="quote">The problem is that the Check Engine Light Stays on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonhatchblack &raquo;</TD></TR><TR><TD CLASS="quote">Used A Buddys Stock P28 and still same Thing. Flashing Check Light.</TD></TR></TABLE>
So which is it?
Old Dec 9, 2004 | 04:43 PM
powerfulperformance's Avatar
check the tps sensor.
Old Dec 10, 2004 | 10:12 AM
Default Re: Check Engine Light NO Codes Bogging At 4K (powerfulperformance)
i'll check the tps.
but other than that.
does anyone knows how to trouble shoot any relays or wirings??
Advise Please.
Old Dec 16, 2004 | 04:53 PM
Just Found out it was the ECU. It first 2 ecu's were burnt.
But whats weird is that w/the stock p28 ecu the engine light is still on w/code: #1 (O2 Sensor)....I switched it with another O2 and still the light still stays on???
The check light did stay off for a good 2 seconds......But Flashes on AGAIN!
Oh yea the BOGGING is now GONE 4 GOOD.
What cAn be the Problem now?
Any Advises?
You Guys or Anyone Reccomend taking it to the Dealer for a Diagnoistic Test?
Or Does the Dealer Basically Check my Good Sensors and Charge me a FAT $$$?
Help Please.
Old Dec 16, 2004 | 05:55 PM
2lua's Avatar
Default Re: Check Engine Light NO Codes (spoonhatchblack)
let see switched to known good ecu, cel for o2 sensor replaced o2 sensor. so now it cel flashing again. so what are the codes?
Old Dec 17, 2004 | 10:04 AM
Default Re: Check Engine Light NO Codes (2lua)
yes.
swapped out bad ecu for good ecu.
check light for o2 swapped out o2 for good o2.
and light still flashes for o2.
codes are:
and
#61
help
Old Dec 17, 2004 | 11:58 AM
boricuatuning's Avatar
Make sure your reset the ecu after installing the good 02 sensor. It will clear all your codes.
Old Dec 17, 2004 | 02:34 PM
itsthatguy's Avatar
Default Re: Check Engine Light NO Codes (boricuatuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boricuatuning &raquo;</TD></TR><TR><TD CLASS="quote">Make sure your reset the ecu after installing the good 02 sensor. It will clear all your codes.</TD></TR></TABLE>
ding ding ding we have a winner............unplug your battery for about 10 seconds and it should reset your CEL
Old Dec 17, 2004 | 02:35 PM
silverEH2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">Yup...constant CEL means its an ECU problem</TD></TR></TABLE>
Old Dec 17, 2004 | 04:49 PM
cvccjdm's Avatar
check out cel checker at Autozone. its free
Old Dec 18, 2004 | 09:29 AM
Just Swapped the o2 and resetted the car..........same thing..
it seems like it got worse...
Im not too sure if autozone can advise me..but it doesnt hurt to try!
Any Other Ideas???
Old Dec 18, 2004 | 05:39 PM
hatchi's Avatar
Default Re: Check Engine Light (spoonhatchblack)
so what are the symptoms now?? did you check all your fuses??
Old Dec 19, 2004 | 09:43 AM
Default Re: Check Engine Light (hatchi)
I Have Checked all my fuses..but i'll check it again just in case...
streetchemistry2000si
Dec 15, 2008 09:42 AM
ef8cybercrx
Oct 13, 2007 04:49 PM
dave24
Mar 19, 2006 08:22 AM
dingusjt
Oct 16, 2003 09:18 AM
