JRSC D16Z6 Install help - Fuel System?
I just picked up a used JRSC from H-T member JBS. I don't want to run the FMU setup and I don't have the enrichment relay.
What are my options for meeting the fuel requirements under boost?
I was considering an AEM FPR and a set of 310cc injectors. I have an old EFI Systems PMS that I can tune the fuel and timing with.
TIA
TIA
Get a set of DSM 450cc injectors. With your PMS, you should be able to get it running fabulous. Does the PMS let you mess with ignition?
well if you decide to run the fmu,
you could just pick up a JR map controller,
it replaces the fuel enrichment relay,and upgrades it, for better control over your fuel.
best thing to do would be to get some bigger injectors and have it tuned with hondata or uberdata or something.
you wouldn't need any fmu or map controller or relay for that.
grand600
Sep 27, 2001 09:58 PM
