HELP!!!!! I KNOW NOTHING??? B18A TROUBLES
I JUST RECENTLY BOUGHT AN 89' CRX SI. I KNOW NOTHING ABOUT IMPORT CARS BUT AM INTERESTED IN GETTING INTO THEM. IT HAS A B18A DOHC WITH 4 MILES ON THE ENGINE AND TRANSMISSION(Y1) MY COMPRESSION RATE IS 11:7:1(.25"O.S.)JDM CTR PISTONS. LOCASH RACING W/RING ADAPTER (OBDO-OBD1. MY MAIN PROBLEM IS MY ECU IS KICKING OUT A CODE OF 7 FLASHES. I CANT FIGURE IT OUT PLEASE HELP.
IF ANBODY READS THIS AND NEEDS ANY MORE INFO ABOUT IT PLEASE ASK. I'M DESPERATE.
THANK YOU.
THANK YOU.
Yep, DTC 7 = TPS
Make sure the MAP and TPS plugs are not mixed up. Check the TPS voltage. It should be close to 0.45V at closed throttle [this value MUST be below 0.50V] and close to 4.5V at wide open throttle. There should also be no 'dips' in voltage or dead spots [0V reading] through the entire opening of the TPS. It should be a smooth increase in voltage from closed throttle to WOT.
leoaa777
13
Dec 28, 2007 01:28 PM
b18cEK
Apr 4, 2006 04:09 PM
