electrical oil pressure gauge question..
Old Dec 7, 2004 | 07:36 AM
graphic's Avatar
Default electrical oil pressure gauge question..
my oil light on my 98 prelude is on and doesn't shut off..i have hooked up a mechanical oil pressure guage and i am getting oil pressure (i don't feel comfortable with this gauge because i have heard if the line slipping and motors dumping like 3 quarts of oil out)...but anyways i changed my oil pressure sending unit to a new one and the light still won't go out...must be a ground problem..
my question is will the electrical one work even with the oil pressure sending units electrical messed up? or can i get and eletrical oil pressure signal from a different wire??/
Old Dec 7, 2004 | 08:14 AM
Monkey Fing a Coconut's Avatar
Default Re: electrical oil pressure gauge question.. (graphic)
an electrical op gauge will come with its own sending unit, so u will remove the stock one connected to the idiot light and put in the other sending unit, then u will run the wire from there straight to the gauge wherever u have it set up, i also have a mechanical gauge that i do not have connected because i fear it coming out...i only use it when i think theres a problem which sucks...
Old Dec 7, 2004 | 10:31 AM
graphic's Avatar
Default Re: electrical oil pressure gauge question.. (twistedbydezign)
will the "Idiot light" go out???
ufakeit
18
Sep 11, 2009 12:44 PM
departed
Jun 3, 2006 12:19 PM
B18badboy
Apr 12, 2006 07:17 PM
jdmcivicferio
Apr 8, 2003 07:20 PM
